Author Topic: CB750F1 rear wheel spacer dimensions  (Read 504 times)
Offline indianchoutracer
« on: May 21, 2024, 02:42:31 PM »
I have some trouble with the rear fork and spacers om my 1976 F1, it seems either is the rear axle 4-5 mm to long or is the drive side spacer possible to short. The one I have is 18,5 mm on the driver side (should be part no. 42311-392-000), and 22,5 mm (should be part no. 42311-357-010 on the brake side.
I would be very grateful if somebody could check their parts stash and measure the right ones.
Re: CB750F1 rear wheel spacer dimensions
« Reply #1 on: May 21, 2024, 10:27:29 PM »
Remind me with PM or email if I don't get back to you
« Reply #2 on: May 22, 2024, 04:43:07 PM »
First and easiest, what is the length of your rear axle? We can eliminate that quickly. 11 7/8" not including the "head" ie shaft only
Spacer (#35 in the book) 42605-300-000 (the -300 indicates this is also a K model spacer) on the flange side 33mm - sprocket side
Spacer (#13 in the book) 42311-357-010 (collar, rear wheel side) by the axle nut 22mm - disc side
Spacer ( #9 in the book) 42311-392-000 (the -392 indicates this is a F0/F1 item) (collar, rear wheel side again) non-flanged 23mm
Hope this helps. If everything matches just look hard at the build/fits
