Author Topic: Right Hand Switch Issue?  (Read 500 times)
Offline Finnigan
« on: May 21, 2024, 08:54:23 PM »
cb750 with standard wire harness and Emgo switches from CognitoMoto.
Left hand switch wiring done with blinkers, headlight, brights and horn working fine.
Right hand switch giving me grief - starter button doesn't give more than a few millivolts at the solenoid and the coils are the same.  There is a consistent reading on the volt meter when the buttons are switched but like I said no more than a few millivolts.  Not sure if the switch is bad but I ohm'd out the connections and they have continuity.
Anyone have ideas on what the problem could be?
Offline Finnigan
Re: Right Hand Switch Issue?
« Reply #1 on: May 22, 2024, 02:41:56 PM »
Resolved, both leads were hot when they were marked differently.  When not following the wiring diagram it all works :)
« Reply #2 on: May 29, 2024, 09:40:51 AM »
 I had one with a displaced switch part. It shorted to the handlebars, there is a hold down tab that holds everything in place in the stock switch, the repro lacked that part and I had dislodged it when pulling the handlebars.
