Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Maxi dwell ?Adjust the points so they never open then you have 360 degree dwell, thats maxi dwell all right.If you set the points to .014" you can check when the points close and when they open, that is the dwell.
I'm still points, I use feeler gauges, tried a dwell meter, got a variety of results, went back to feeler gaugeI'm old
Ditto….you can always carry a spare set of points on a trip and fix it on the side of the road. Try that with electronic ign.
Guess I’ll have to figure it out myself
