Author Topic: CB350F Best video/online ref for carb reassembly?  (Read 381 times)
Offline Vfrman
« on: June 10, 2024, 03:49:50 PM »
Anyone have any favorite vids/refs for reassembling the carbs after complete breakdown?  I hope I don’t have a complete breakdown :-[
1973 CB350F
many bikes over many years
Re: CB350F Best video/online ref for carb reassembly?
« Reply #1 on: June 10, 2024, 08:40:39 PM »
Got tweezers?
:D
Offline Deltarider
« Reply #2 on: June 11, 2024, 01:11:12 AM »
That will be Marco on the German forum. He first made very good videos on both the dissasembly as well as the reassembly of his CB500 carbs. There are about 8 or 9 videos of them, each about 20 minutes! He is gründlich and does explain well in his soft and modest voice. BTW, all his vids are free of bragging and pretending, a true relief... CB350F carbs are very similar. He also made vids on the assembly of his CB350F carbs. In total some 165 minutes. His channel: https://www.youtube.com/@motormac3657 I've just discovered you can opt for subtitles in English. You'll be impressed.
« Last Edit: June 11, 2024, 03:59:56 AM by Deltarider »
CB500K2-ED Excel black
Offline Vfrman
« Reply #3 on: June 12, 2024, 04:52:07 AM »
Many thanks!  Give me a chance to use my German! -no wait, I only know girl flirting from 1983 in the Army😜
1973 CB350F
Offline Vfrman
« Reply #4 on: June 12, 2024, 04:57:43 AM »
This corrosion tore one of my brand new o-rings (Julie sent me) when I was putting the jet back in on top of the needle😭. Not a complete tear…shaved off maybe 25% of the tiny oring. Now I don’t know whether I should leave it there or put an old O-ring on it, only one of the 4 didnt crumble when I took it off.
After that one tore, I used a very fine rat tail file to smooth up the inner edge circumference of all the other towers on the remaining carbs and had no further problems
1973 CB350F
Offline Rayzerman
« Reply #5 on: June 14, 2024, 04:50:01 AM »
Here's some good reading material, I'm about to start this job myself when my rebuild kits arrive......
https://www.vintagebikebuilder.com/cb350-400f-carb-rebuild-demonstration.html
Offline Vfrman
« Reply #6 on: June 15, 2024, 05:01:45 PM »
Using the above guide- the dude fails to mention re-installing the leaf spring after installing/setting the floats….he says “then you can instal the float bowls”!  I got 2 back together when I looked over in my muffin tray and saw them and thought “hey they should go in before the bowl cover is screwed on!!
1973 CB350F
