Author Topic: 400F pinches carb bowl gaskets  (Read 820 times)
Offline jakec
« on: June 15, 2024, 02:46:58 PM »
Stupid spring load jets on this bike means you have to install the bowls awkwardly, often resulting in pinched gaskets. Oddly enough this isn’t a problem on the 350 twin because the gaskets are willing to stay stuck in the groove on the bowl. Not on the 400 though. These are 4 gaskets of mine that pinched over the years.
Eventually I started using superglue to hold the gaskets in place, which worked great. But then, not sure why but the bowls started leaking like crazy. I think due to the gaskets drying out but also being held in place by the glue. So I guess I won’t be doing glue anymore. I’m scraping off the glued on gaskets now and about to install new. Wish me luck. I may use a dab of assembly lube to hold them in this time.
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Offline denward17
Re: 400F pinches carb bowl gaskets
« Reply #1 on: June 15, 2024, 02:51:33 PM »
I used a dab of grease in each corner.  No leaks so far, only been a couple of months though.
Online Mark1976
« Reply #2 on: June 15, 2024, 02:57:30 PM »
Been doing it that way for decades.
Start with the end in mind...
Offline jakec
« Reply #3 on: June 15, 2024, 04:55:37 PM »
Been soaking these new gaskets in gas for 2 hours trying to make them larger, they aren’t fitting. I have had this problem before with 350 gaskets. Not sure about the 400 though. They’re taking their sweet ass time
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jonda500
« Reply #4 on: June 15, 2024, 04:56:46 PM »
I have used super glue on the round ones and grease on the house shaped ones to hold them in with no problems - they originally seem to be glued in with gasket goo or similar?
Bowls leaking like crazy (assuming the bike is upright) would indicate a problem with the needle and seat valves as well as leaking gaskets - maybe you have the too small diameter rubber cross section ones that have been showing up on ebay lately? - they should sit proud of the slot they sit in...
John
A starter clutch thread:
Offline jakec
« Reply #5 on: June 15, 2024, 05:12:10 PM »
The bike was running fine for a couple thousand miles, #2 carb started a small slow leak which was caused by a pinched gasket. I replaced (from the set of 4 I’m using now) and used super glue and it was fine for a couple hundred miles. Then #3 cylinder went coldish one day, and I pulled the carbs installed same old gasket from years ago using super glue again. Bike ran good after that, but after running it for a while I realized the two carbs that I’d used glue on were pissing gas out the top (indicates bad gasket to me, not valve or float as there was no overflow coming out).
I think what happened was I used too much glue and then the gaskets shrank while the carbs were off the bike, and the gaskets got stretched or out of whack somehow.
So I have used 1/4 gaskets from this set without problems for a couple hundred miles, I think they are fine. I’m pretty sure it was just going way overboard on the glue and then letting them dry out
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #6 on: June 15, 2024, 05:20:53 PM »
Just said #$%* it and did glue again but used like 1/10 of what I did before
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jonda500
« Reply #7 on: June 15, 2024, 05:21:36 PM »
The brass overflow tube is higher than the top of the bowl and the fuel level (assuming fuel valves are all good) should be just under the top of the bowl?
John
Offline jakec
« Reply #8 on: June 15, 2024, 06:31:38 PM »
True but if there’s no seal on the bowl then the level can’t get high enough to reach the overflow tube. It’s all back together now and seems good. I tested for leaks before installing on the bike this time.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #9 on: June 17, 2024, 07:49:25 AM »
Super glue will destroy the o-ring gaskets.
Use a tiny bit of permatex gasket sealer in the corners just to hold in place. Or grease.
« Last Edit: June 17, 2024, 07:51:03 AM by Ozzybud »
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #10 on: June 17, 2024, 08:01:01 AM »
Never had a problem using ordinary clean grease
Online Mark1976
« Reply #11 on: June 17, 2024, 09:20:22 AM »
+++++++1
