Author Topic: Honda SL350 K0 Rear Shock Removal  (Read 669 times)
Offline pjandrew99
« on: June 24, 2024, 04:36:35 AM »
Currently have aftermarket cheap shocks on bike installed by PO. I want to remove and install the OEM shocks.
The bottom bolt hits the exhaust when trying to remove, not allowing me to pull the bolt all the way out. Before I mess with the exhaust, are there any tricks to removing the shocks without loosening or removing exhaust?
Also, on the install, can I turn the OEM shocks so the bolt removes on the wheel side instead of the exhaust side? Would that create any issues? Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Honda SL350 K0 Rear Shock Removal
« Reply #1 on: June 24, 2024, 08:14:32 AM »
I think removing the exhaust is unavoidable. Be sure to use some penetrating oil on any fasteners you plan on removing. Turning the bolt around might not work, you'll have to see if the head gets in the way of anything.
Look on the bright side, you get to clean up all the parts you remove!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline pjandrew99
« Reply #2 on: June 25, 2024, 04:11:52 AM »
Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
