Author Topic: Plugs and Threads  (Read 449 times)
Offline TheHulk
Plugs and Threads
« on: June 30, 2024, 12:25:10 PM »
The #3 cylinder plug on my 77 CB550 makes me nervous.
I've successfully removed and installed new ones a few times, but I'm afraid of stripping the threads eventually. All other plugs I am able to hand tighten all the way to the crush washer, but #3 requires a wrench for every turn.
Would a little bit of never cease on the plug threads dirty up the cylinder? Would motor oil do the trick instead? Would removing a plug from a hot vs cold engine be better in the long run? Anyone with common issues or suggestions? Thanks!
Re: Plugs and Threads
« Reply #1 on: June 30, 2024, 01:09:30 PM »
I used grease or anti-seize on all plug threads, every time.
The 500/550 has troubles with the #3 sparkplug because of the nearby tach drive: the Honda toolkit came with a special tapered-top sparkplug wrench just for that reason. This wrench clears that tach drive so you can use the screwdriver's insertable shank as your torque-tool. If you don't have that wrench, maybe try to get one at the local bike junkyard: many other bikes copied the method after that.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: June 30, 2024, 01:58:36 PM »
I made my own tool, works better in all 4 pots. And yes I use antiseize also in all my vehicles. Steel threads in an aluminum head, if left a while can corrode due to being bi-metal.
« Last Edit: June 30, 2024, 02:07:11 PM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Kelly E
  • Geriatric Hooligan
« Reply #3 on: June 30, 2024, 02:10:24 PM »
We use a 12" length of 3/8" fuel line to install and remove spark plugs. It allows you to get the plugs started without cross threading them. If it tries to cross thread you can feel it.
We use the Honda tool to loosen and tighten the plugs. We use the same Honda tool on most of our bikes no matter what brand the bike is. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #4 on: July 01, 2024, 12:16:00 AM »
I use aluminium paste on my plugs. It withstand +1100*C
Just a little on the threads.
I like to tighten plug down mostly by hand.
New plug will get a little paste on its thread.
I use the std tool Honda delivered in the CB750 tool box.
Offline willbird
« Reply #5 on: July 01, 2024, 07:28:34 AM »
I just use clean fully synthetic motor oil on the threads myself, have had no issues so far.
Bill
« Reply #6 on: July 01, 2024, 08:09:10 AM »
Coppaslip for the last 50 years
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #7 on: July 01, 2024, 10:12:41 AM »
I use the Craftsman version of this thread restorer kit for many threaded holes in aluminum:
https://www.amazon.com/Thread-Chaser-Repair-Rethreading-Restorer/dp/B0BH8QSHTF/ref=asc_df_B0BH8QSHTF/?tag=hyprod-20&linkCode=df0&hvadid=692875362841&hvpos=&hvnetw=g&hvrand=11216617108048682754&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1015150&hvtargid=pla-2281435178578&mcid=de492933fd79386891b8c541fe5af30d&hvocijid=11216617108048682754-B0BH8QSHTF-&hvexpln=73&gad_source=1&th=1
 They are much less aggressive than a standard tap and they tend to "push" threads back into place as opposed to cutting. As with all things threaded into aluminum you must start slowly and ensure that the tool is straight and true. I get so much use out of mine that I actually bought the bigger set too.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline TheHulk
« Reply #8 on: July 01, 2024, 01:16:30 PM »
Thanks as always HondaMan! I'll look into this tool. I have a semi custom one that seems to fit in correctly, but I'll keep investigating.
Thanks everyone else as well!
Offline Deltarider
« Reply #9 on: July 02, 2024, 08:05:32 AM »
Same here, be it 44 years.
CB500K2-ED Excel black
