Author Topic: Looking for a website/chart that gives specs(width:pin lengths,etc.)for chains  (Read 3604 times)
Offline grcamna2
Can you recommend a site to give specs/measurements for different brand and size drive chains ?
75' CB400F/'bunch o' parts'
Offline Tracksnblades1
See if this is what you’re looking for…
Go down to the chart that shows all the chains’ specs..
https://rkexcelamerica.com/products/rk-chains/
Check chains with ISO 10190 ratings “motorcycle chain” RK and Regina are for sure..
Don’t confuse ISO 606 rated chain “industrial chain” with motorcycle chain…
« Last Edit: July 05, 2024, 06:36:22 AM by Tracksnblades1 »
Age Quod Agis
Offline grcamna2
ISO 10190 for motorcycle chain,ok.
Offline grcamna2
I called a few motorcycle parts places(nationwide parts houses)and they couldn't give me specs on the width/pin length of other drive chains except EK from a small distributor;then Dennis Kirk,no.  ::)
I see the RK chart from 'Tracksnblades1' which gives me some information..
Are you worried about an o-ring chain rubbing and just doing your due diligence beforehand?
They have a new skinny oring offering for old bikes but I’ve never used it..I’ve always ran a RK regular (wide) oring chain with no problems with a 17 or mostly a 18 tooth front sprocket..76F1 though I know the same works on a 75k with a 16 on front..
Age Quod Agis
Offline grcamna2
Do you know the brand for the skinny o-ring chain ?  RK?  :)
I like 70's,80's vintage bikes and O-ring chains & would rather be safe than sorry  ;)
Yes it’s on the chart..
Age Quod Agis
Offline newday777
I like the specs on that RK 530uwr
At 22.7mm outside the pins that is 3mm thinner than the regular oring RK chain I have now(not running a chain guard because it rubbed)
https://www.cspracing.com/rk-chain-sv530uwr-100/rkc-sv530uwr-100/
Stu
My current rides
Prior bikes....
Offline grcamna2
I also like that UWR   ;)
« Last Edit: July 06, 2024, 09:38:30 PM by grcamna2 »
Offline Kevin D
  • SE Michigan
https://www.ibtinc.com/wp-content/uploads/2016/03/Diamond-PowerSports.pdf
Maybe this has some info that you want for Diamond chain
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Looks like the XLO’s are the only diamond chains that are even close to the RK’s skinny chain’s tensile strength.
If you’re going to run a standard width 530 oring might as well get the 11,200# tensile strength RK…
Age Quod Agis
Offline willbird
The 520XRE is what I would buy for my 2023 CB500X. Would measure the stock chain width first.
Offline grcamna2
I want to stay with a 530 chain.
Offline willbird
I do not doubt that, my CB500X came with a 520. But a good 520 is plenty strong enough for most of the SOHC users here. When I end up needing a chain on my K2 I am thinking to use a good quality 520.
Bill
Offline grcamna2
Bill
I understand.
I like to keep my same 530 size sprockets;more choices when I look for a deal.
I was considering trying to run a 520 O-ring chain on 530 sprockets,but the sprockets are too wide.
Do you know of a place I can go to machine-down/surface grind my two sprockets to match the width of a 520 chain ?  I'd like to own a surface grinder:use to operate one.
« Last Edit: July 08, 2024, 10:35:38 AM by grcamna2 »
Bill
I understand.
If you know someone with a lathe, modern tool bits or inserts will trim them down to size in a hurry..
I would take the same off of both sides of the front and rear sprockets where the teeth are to maintain the same chain center line, while leaving the OEM sprocket thicknesses alone at the rear wheel and the front’s splined retainer area.
You may look into retempering the teeth area if you think the turning removed it..
Age Quod Agis
Offline newday777
But aren't the teeth a different space too?
Stu
My current rides
Prior bikes....
Both 530 & 520 are 5/8” pitch chain. The 530 is the wider one. The 520 is the narrow one that’s  been used on dirt bikes forever.  Some 520 chains today are rated for 200hp.. They’ll last near forever on a 50hp dirt bike..
I think he’s wants to run a full oring chain on his bike. He’s looking for a narrower chain so he can but his chain guard back on. I mentioned tuning both sides so he doesn’t upset Honda’s original chain alignment or center line.. by turning both sides he’ll get a little more clearance on both sides compared to his 530.. more clearance for his chain guard on the outside and more clearance for his tire on the inside and chain guard if applicable on his bike..
Age Quod Agis
Offline grcamna2
I like the looks of that RK 530UWR very much.
Offline grcamna2
Kevin,the small numbers on that chart are too blurry to read.
Offline Kevin D
  • SE Michigan
Sorry pal, maybe these 400kb screenshots will help.
The pdf looks like it’s 8 years old. I had a helluva time finding it.
And maybe doesn’t represent the Diamond product of today:
Looks like Diamond was purchased by Timken in 2019 and production moved
from Indianapolis to Fulton, Illinois and Weifang, China.
WTH is this BS? Diamond chain from China not Indianapolis
« Last Edit: July 08, 2024, 09:06:54 PM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Offline grcamna2
Thanks,now it's very clear.
I'm shocked;Diamond of Indianapolis closed down,no more USA made blue side plates  :(
Offline willbird
One article said Timken was moving production to IL ?? An article said that the Indy plant was built on top of a cemetery used to bury Confederate POW during the Civil war.
Offline Kevin D
  • SE Michigan
I have the box from my own Diamond chain, this is its third season.
There is an American flag on the box and it’s marked Indianapolis.
I browsed around the Timken/Diamond website an bit and couldn’t find any sections for PowerSports chains, mainly industrial applications. I did see a section on XLO and duralube chains. This website wants you to make an account to dive into its site more deeply, and I did see J & P cycles, Tucker/Rocky as distributors.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Offline grcamna2
I see. I hear that Duralube is an excellent chain w/ long life.
I like the NOS Diamond standard chain very much as the side plates are quite narrow and fit many different applications.
I've never installed a Diamond O-ring chain yet.
