Author Topic: Weird Points Plate Issue  (Read 380 times)
Offline jaytee-nz
« on: July 04, 2024, 08:01:26 PM »
I was fine tuning the timing on my 72 CB500 with my timing light and as I tightened up the last of the three screws that hold the plate on, the bike started to stumble and the idle nearly died. I backed off the screw and the idle returned to normal !
Tried this process about 6 times and the same thing occurred.
The plate is properly positioned in the case recess and is not warped. Tightening the screw can only move the plate a tiny fraction as it's already touching the recess area. Everything else looks normal.
Anyone come across this issue before ?
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: Weird Points Plate Issue
« Reply #1 on: July 04, 2024, 08:20:44 PM »
Pinched wire under the plate?
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #2 on: July 04, 2024, 08:27:06 PM »
Yes, I have. :) You need to check the timing with the three screws just snugged down. Then, if adjustment is needed, shut the engine off, adjust the points plate where you think it needs to be, snug the screws, start the engine, and check again. Repeat as needed. Once you are satisfied, give the screws a final tighten. ;D
Offline jaytee-nz
« Reply #3 on: July 04, 2024, 08:34:29 PM »
Thanks Scottly.
I guess the points "foot" is not sitting square on the shaft due to the screws being too loose (or is moving around) and tightening the screws is changing the foot position. Off to the garage !
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #4 on: July 04, 2024, 08:55:30 PM »
Is it a new points plate? I've heard of issues with some aftermarket brands.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline jaytee-nz
« Reply #5 on: July 04, 2024, 09:41:01 PM »
No, it's the original Hitachi plate so no issues there.
I took Scottly's advice and it all seems good now.
