Author Topic: cb350F Head Gasket Seep  (Read 493 times)
Offline 574hondarider
« on: July 25, 2024, 10:13:46 AM »
Hello All,
It's been awhile since I've been on.  Fully restored 73 cb350F back about 3 years ago.  I used oem honda gaskets with the copper spray.  No leaks or seeps for 2000 miles.  I haven't ridden the bike much at all this year and took it out for a spin and noticed the infamous weeping on left side of the bike around the head gasket.  I'm thinking I may try to loosen, then tighten all the engine bolts in the correct pattern, but was wondering if anyone had any thoughts on this, esp. given the fact I used the copper spray.  Thanks so much!
« Last Edit: August 23, 2024, 01:02:19 PM by 574hondarider »
Offline BenelliSEI
  • 1969 cb750
Re: cb350F Head Gasket Seep
« Reply #1 on: July 25, 2024, 11:04:44 AM »
Could be just the copper spray. Clean it up and run it some more…..
Offline Mark1976
« Reply #2 on: July 25, 2024, 11:56:16 AM »
   I'd go John's route, then if it continues you can decide what to do, you could re torque and then if that fails its time to replace the HG and accompanying seals. It's a common issue (the leak), but it could be the copper coat weeping thru. One thing at a time.
Start with the end in mind...
« Reply #3 on: July 25, 2024, 12:59:27 PM »
Thanks guys.  It's definitely oil but just a few drops.  Maybe I'll try retorquing in a few weeks or let it roll until it gets worse.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: July 25, 2024, 02:48:15 PM »
Good plan. I had a K8 that did that for +10 years before I pulled the motor. Wiped it down regularly and really the oil loss was virtually nothing…..just annoying.
Online newday777
« Reply #5 on: July 25, 2024, 07:53:09 PM »
Maybe it's not the headgasket but the oil sealing pucks have shrunk from lack of use. Wipe it down as you said and ride it more to get them to seal up as you ride.
Stu
My current rides
Prior bikes....
« Reply #6 on: July 25, 2024, 08:40:08 PM »
The O-ring that passes the oil pressure thru the head gasket is VERY LIKELY too thin by 0.2mm or so. This is because all these head gaskets are now thicker by that much since asbestos was outlawed: the gaskets that replaced those are 0.2mm thicker.
BUT...here's the kicker...there are not seals available for the oil jets that are 0.2mm taller. So what must happen to restore the seal integrity of that spot is:
mill the cylinders down 0.02mm (0.010" works fine, too) on their top.
Sorry, but that's what the cause is, and how to fix it for real... :(
Online PeWe
« Reply #7 on: July 26, 2024, 12:57:33 AM »
I used copper spray on a graphite head gasket on a CB750. A mistake.
It leaked oil rather soon. Higher compression with 836 helped the leak to happen early.
My local shop's mechanic that has tuned/modified all kinds of bikes since mid 70's told me to mount graphite gasket dry, no copper spray.
« Last Edit: July 26, 2024, 05:52:47 AM by PeWe »
« Reply #8 on: July 26, 2024, 03:05:57 AM »
Never use anything on a standard gasket
Offline Mark1976
« Reply #9 on: July 26, 2024, 06:43:38 AM »
+1 to that.
« Reply #10 on: August 23, 2024, 01:01:33 PM »
It does not appear to be leaking anymore, so I'm thinking riding it a bit fixed the issue!
Online newday777
« Reply #11 on: August 23, 2024, 02:31:15 PM »
The rubber pucks swelled with the heat and oil hitting them to seal it.
Stu
My current rides
Prior bikes....
