Author Topic: Oil Pump Screen  (Read 434 times)
Offline M 750K6
Oil Pump Screen
« on: July 26, 2024, 02:54:50 PM »
The manual says clean the screen every 6,000 miles. When I looked at it, with the engine out (to rebuild my top end), despite easy access, I wasn't able to get the screen out of its housing. It felt like I was close to breaking the outer rubber ring. It wasn't too bad, so I pulled any muck off (tweasers!), which looked more like dirt and soft fibre, non metallic, gave it a wipe over and left it alone.
Two questions:
- Does everyone clean the mesh filter every 6,000 miles?
- How robust is it, is there a trick to getting it out without destroying it?
Thanks,
Martin
Offline BenelliSEI
  • 1969 cb750
Re: Oil Pump Screen
« Reply #1 on: July 26, 2024, 05:04:22 PM »
Martin…… Like you, I just clean it and leave it. Probably easier when the bikes were new, but after so many years and heat cycles, I’m sure they would shatter. Either have a new one on hand or leave it in place…..
Re: Oil Pump Screen
« Reply #2 on: July 26, 2024, 06:56:31 PM »
The rubber ring covers a steel ring of the screen. I use a tiny flat-blade screwdriver to slowly coax them out.
But - cleaning them every 6000 miles always sounds silly when I didn't see mine until it had 50k miles on it, and it was still clean?
Then again, that last sandcast I did required it be soaked for 4 days in solvent before I could GET it clean...
Offline M 750K6
Re: Oil Pump Screen
« Reply #3 on: July 26, 2024, 11:19:32 PM »
Thank you. While the oil is coming out clean, I'll just check it occasionally and clean in-situ.
Re: Oil Pump Screen
« Reply #4 on: July 26, 2024, 11:35:24 PM »
Remove dirt from outside only. I'm sure the strainer will be deformed and fall out if removed several times.
There are new to purchase if bad.
I have never seen particles inside it.
A good idea to clean it 1000 km after a complete engine restore. Particles as sealer etc can sit in the nets outside.
I have not found much dirt after 10.000 km after engine restore.
If engine has been sitting for a long time in a humid place rusting, rust flakes might fall off if starting the engine.
Small parts from clutch fiber plates can sit there too.
Very important to clean it on a bike sitting many years. The strainer can be blocked by  oil sludge blocking the pump, engine will get no oil when tank no longer will get oil.
Honda gasket sealing the pan will accept removal of pan several times without replacing the gasket.
Important to not use additional sealer.
« Last Edit: July 27, 2024, 01:47:18 AM by PeWe »
Offline newday777
Re: Oil Pump Screen
« Reply #5 on: July 27, 2024, 01:41:34 AM »
Was that the red dirt/clay coated sandcast restore thread?
Stu
My current rides
Prior bikes....
Offline Deltarider
Re: Oil Pump Screen
« Reply #6 on: July 27, 2024, 02:31:53 AM »
The first time I inspected the oil filter screen the engine had already done over 75.000 kms. Screen was spotless. 55.000kms later I checked it again. Again spotless. A few specs. I didn't even bother to clean it.
Same with my yacht. After 27 years I inspected the oil screen of my marine diesel engine for the first time. Screen was spotless. I'd say, leave it alone.
« Last Edit: July 27, 2024, 02:36:43 AM by Deltarider »
CB500K2-ED Excel black
Re: Oil Pump Screen
« Reply #7 on: July 29, 2024, 08:50:30 PM »
Yeah, that was the one. I thought it was a goner, but after soaking (forgotten, actually) most of a week I picked it out and a bunch of the crud came off in one big pack. It was a red dust (common around Houston where it came from) mixed with oil and water, made a nice paste. :D
