Author Topic: 500/550 rearset cast  (Read 2122 times)
Offline wolf550
Re: 500/550 rearset cast
« Reply #25 on: August 10, 2024, 12:01:37 PM »
with the triangle bracket cognito defintely fixed all the problems these C brackets give
74' CB550 (Sold)
71' CB500/550 (Sold)
Offline grcamna2
« Reply #26 on: August 10, 2024, 02:33:57 PM »
Offline wolf550
« Reply #27 on: August 23, 2024, 05:50:50 PM »
had some time to work on these after long stint at work.
74' CB550 (Sold)
Offline wolf550
« Reply #28 on: August 23, 2024, 05:52:03 PM »
got the holes sized right. still ned to drill the lever hole for the right side.
74' CB550 (Sold)
Offline wolf550
« Reply #29 on: August 23, 2024, 05:53:13 PM »
I wanted to keep some of the casting look to these so I did up the lip
74' CB550 (Sold)
Offline wolf550
« Reply #30 on: August 23, 2024, 05:54:17 PM »
has a nice grainy look to it but can be sanded smooth also.
74' CB550 (Sold)
Offline wolf550
« Reply #31 on: August 23, 2024, 05:54:51 PM »
more pics
74' CB550 (Sold)
Offline wolf550
« Reply #32 on: August 27, 2024, 06:12:56 PM »
getting ready to pack these up. had fun learning some stuff about them. after getting the tape and sand out of the original steel rearsets, I decided to try them on the pegs. seems the bone rearset front hole is kinda big for where the foot rest is but it fits in the swingarm peg hole for some reason. I tried the C rearset bracket they were switched. the lower hole is big for the foot rest but fits in the swingarm and the upper hole fits in the footrest but does not even fit in the swing arm peg. I thought maybe my bolts were switched but the footrest wouldnt fit on the swingarm end and visa versa. well I will never know. yes with that tab there the C rearset bracket will not fit unless modified or removed.
74' CB550 (Sold)
Offline grcamna2
« Reply #33 on: August 27, 2024, 06:29:19 PM »
The one that's black painted lines-up ok.
Offline bassboy3313
« Reply #34 on: August 28, 2024, 10:09:29 AM »
Hi. What thickness of material are these brackets by chance? Thank you
Offline wolf550
« Reply #35 on: August 29, 2024, 12:46:07 PM »
it is just like the others where it will fit but that tab is blocking it from fitting all the way. since it is just the screw for the brake lever it could be grinded down some for clearance.
74' CB550 (Sold)
Offline wolf550
« Reply #36 on: August 29, 2024, 12:48:02 PM »
hi bassboy it looks like 1/2 inch for the steel original and a little less than that for the aluminum reps. FYI these are going to be going back to seanbarney if you want to hit him up again about them.
74' CB550 (Sold)
Offline bassboy3313
« Reply #37 on: August 29, 2024, 12:51:31 PM »
Thanks! I designed some up in AutoCAD and will be getting them CNC cut from 6061 Aluminum. Just wasnt sure if 1/4" was thick enough or if I should go up to 3/8". I will most likely go with 3/8" material.
Offline wolf550
« Reply #38 on: August 29, 2024, 06:36:14 PM »
the triangle rearset I cast were 1/4 inch and I could stand up on them all day long. I never did the stand test with these but I didn't think I would use them to stand on.
74' CB550 (Sold)
« Reply #39 on: August 29, 2024, 07:34:36 PM »
Yeah, it looks like Cognito assumed that anyone wanting rearsets is more than happy to be cutting off any "unnecessary" frame tabs.
