Author Topic: Engine rattle  (Read 1058 times)
kaysix
Engine rattle
« on: March 19, 2007, 02:29:19 PM »
I'm now well into the rebuild of my 1975 CB750F. I have recently bought another one to use for parts, the first bike came with it's engine busted (drive chain snapped) The engine on this second bike is a runner, but there seems to be a lot of rattling from the cam chain, which I have adjusted as per the manual. The engine seems to quieten down as it gets warmer and if the revs are kept above 1500rpm.
It's been over 20 years since I last had a CB750 or heard one running, I seem to remember the engines being a bit noisey at tickover and particularly when cold, but I'm unsure what is considered as normal. This engine has covered about 57,000 miles, I don't know if any previous work has been done to the engine. What is considered a reasonable life span for cam chain and tensioner, and primary drive chain? I don't mind doing a top end rebuild, but don't fancy splitting the cases to do the rest.
Offline mack808
Re: Engine rattle
« Reply #1 on: March 19, 2007, 02:36:14 PM »
If the engine or cam chain noise quiets down just off idle, thats probably a good sign that the carbs are out of sync and the noise you are hearing is the primary imbalance caused by unequal idle speeds in the 4 cylinders.   Try synching carbs and this should cure your noise at idle.....
CB350 twin vintage road racer, CB350F project, GS750es daily rider, NS400r play bike, 2 MB5s, Z50r project, CB500/590 vintage racer built for friend, CT200 project, and a Gina (Gilera copy made in Argentina)...  And ?????
Re: Engine rattle
« Reply #2 on: March 19, 2007, 04:26:15 PM »
Does the noise abate when you pull in the clutch?
