Author Topic: 1974 CB550k Boss Maroon  (Read 12021 times)
Offline brett_bike
  • '73 CB500 Four K2
Re: 1974 CB550k Boss Maroon
« Reply #25 on: August 02, 2024, 09:30:46 AM »
Question about the valve noise.
How much ticking is too much?  It seems to more pronounced on the left side.
Offline denward17
« Reply #26 on: August 02, 2024, 09:41:35 AM »
Does it sound like this?
https://photos.google.com/share/AF1QipOUyM6MpkfP7248ZiIL8KMXyWb37uK8U0pSa8KsLpw6qTq8_8R-_CxCzmq1lNrPHA?key=RW5XNVlRdi1KQXJJVnNvME9JUjlaaDJsZjBHZk1B
That's my '76 550 that had a bad valve cover rocker shaft, and I recently installed a rocker cover from a '77/'78 model that has pinned shafts.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #27 on: August 02, 2024, 09:57:52 AM »
I don’t think so.  Hopefully not.
I had to do that mod to my old 73 500.
I can hear a different sound coming from the back side of the cylinder from the front of the cylinder so I’m hoping it’s just a rocker adjustment.
If I can figure out how to post a vid I’ll update.
« Reply #28 on: August 02, 2024, 03:55:17 PM »
Pulling end caps on rocker cover you can see ends of shafts and if worn significantly it will be clearly visible.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #29 on: August 02, 2024, 04:37:04 PM »
With only 8700 miles on it, I doubt the rocker shafts are badly worn.
Did you install fresh plugs or clean up your old ones after the carb adjustments?
I cleaned up the old plugs and took her for about a 20 min ride. I had to run to work but I’ll check them when I got home.
Online Stev-o
« Reply #30 on: August 05, 2024, 07:52:06 AM »
My 550F sounds like a sewing machine!  Have you sync'd the carbs yet, that may quiet it a bit?
Offline brett_bike
  • '73 CB500 Four K2
« Reply #31 on: August 12, 2024, 01:19:48 PM »
I removed the carbs to redo the bench sync. I’ve also redone the valve adjustment.
I’ve been out of town in a work trip but getting home tonight, so tomorrow the carbs go back on and final (hopefully) vacuum sync.
Will report back after test ride.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #32 on: August 18, 2024, 10:19:13 AM »
Finally had some time to take the Boss for a ride this morning.
We were out for about 20 minutes and here’s what’s up…
Idle screw is turned in more than I’d like so it won’t die on startup. After warm up it idles about 2500 RPM’s so I have to turn idle down to 1000-1200 at the next stop sign. Then it’s fine for the rest of the ride.
Mostly strong pulling until between 5-4k RPM’s. Then it’s stumbles/blubbers a bit till I give it more throttle then she screams up to 9k.
Offline denward17
« Reply #33 on: August 18, 2024, 10:57:31 AM »
What do your plugs look like now after the ride?
Offline brett_bike
  • '73 CB500 Four K2
« Reply #34 on: August 18, 2024, 11:54:43 AM »
Offline brett_bike
  • '73 CB500 Four K2
« Reply #35 on: August 18, 2024, 11:55:12 AM »
Left to right…1234
Offline denward17
« Reply #36 on: August 18, 2024, 12:10:21 PM »
So you leaned it out by lowering the needle one clip, right?  What position is the needle now and did it run like this before you adjusted the needle?
Offline brett_bike
  • '73 CB500 Four K2
« Reply #37 on: August 18, 2024, 12:22:42 PM »
I lowered the clip, raising the needle.
It stalled before the latest “fix”. Now it at least rides without dying when I come to a complete stop.
Offline denward17
« Reply #38 on: August 18, 2024, 04:42:12 PM »
What is your air/fuel mixture screws set to?
Offline brett_bike
  • '73 CB500 Four K2
« Reply #39 on: August 18, 2024, 04:46:09 PM »
1 1/2 turns out.
Offline denward17
« Reply #40 on: August 18, 2024, 06:56:39 PM »
You could try different settings on the air/fuel mixture to see if it makes a difference.  Try 1 turn out, then try 2 turns out.
Offline grcamna2
« Reply #41 on: August 18, 2024, 11:51:31 PM »
Nice find, don't see original Boss Maroon that often.  +1...change condensers with known OEM
Real nice looking bike;a previous owner kept it inside  ;)
75' CB400F/'bunch o' parts'
Offline brett_bike
  • '73 CB500 Four K2
« Reply #42 on: August 19, 2024, 10:18:08 AM »
Thanks grcamna2, but it looks better in pics that in person. However, this isn’t going to be a show bike. I intend to put some serious miles on this little thing.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #43 on: August 23, 2024, 11:26:38 AM »
Update…
Clip in middle setting. New plugs.
After a 30 minute ride here is what the plug deposits look like. 1-4 left to right. Oddly enough1 & 3 look ok, maybe a little rich.  But 2 & 4 look really lean.
What could I be missing?
Offline brett_bike
  • '73 CB500 Four K2
« Reply #44 on: August 23, 2024, 11:58:05 AM »
I have never placed much value in reading plugs after a “ride” because their condition does not tell you position of throttle that the state is occurring. It is best practice to start clean, fresh plugs, and do a plug reading at idle. Then again at WOT and chop the motor. Pull the plugs roadside and snap pictures of them. Then return to the garage to make any adjustments needed.
From looking at the picture, I’d say your fuel level is wrong on the carbs if all other settings are equal. If the bike is running strong, that somewhat rules out ignition issues, but not entirely.
I plan to pull the carbs again and verify everything.
Thanks
Offline brett_bike
  • '73 CB500 Four K2
« Reply #45 on: August 28, 2024, 08:45:48 AM »
Thanks for all the input calj737!  I really appreciate all the assistance.
One thought/question…
Would the fuel lever still make the bike stumble  at approximately 1/4 throttle?
Offline brett_bike
  • '73 CB500 Four K2
« Reply #46 on: August 28, 2024, 02:24:58 PM »
I’ve seen those.
Ramon thoughts in no particular order…
I’m wondering if the fuel lever would cause the plugs (1 & 3) to foul.
I’d imaging if it were spark it would be 1/4 or 2/3.
I’ve been searching the forum and came across an article that mentioned the needles being wore down, possibly from cleaning I guess, and allowing more or less fuel to pass.
I’m going to dig back in to make sure I didn’t miss something inside the carbs and inspect the needles and emulsion tubes. I feel like other than fuel level in the bowls that’s where I should focus.
Also, I’ll be doing a WOT plug chop in the next couple of days and report my findings.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #47 on: August 28, 2024, 03:45:21 PM »
Needle position confirmed #4 from top (stock)
Yes, clear tube confirmed fuel level.
Offline denward17
« Reply #48 on: August 29, 2024, 06:51:35 AM »
Should be 2nd from top (if you consider the tip the bottom). If you’re in the second from the tip, you’re too rich.
I had to go to the center position to lean my '76 550 out some on the bottom end.  When I tore into carbs they were in the 4th position from top, or 2nd from tip.
The bike runs much better when at operating temp, but doesn't run quite as well when cold.  I now have to fiddle with the choke a little bit more, which I am ok with.  I guess I made it a little more cold natured.
Don't know if it matters, but I also installed new Honda needles/emulsion tubes.
Offline grcamna2
« Reply #49 on: August 29, 2024, 07:29:51 AM »
Den,I've installed some special thin washers to go about a 1/2 step(+ or -),rather than a complete clip notch;it takes a little looking to find the washers that will be just right.
