Author Topic: hows this rocker cover look?  (Read 641 times)
Offline wolf550
« on: July 31, 2024, 07:13:40 PM »
need some input about two areas on this cover. it is going on a full rebuild so no leaks. they are on the inside of the gasket
74' CB550 (Sold)
71' CB500/550 (Sold)
Offline calj737
  • I refuse...
Re: hows this rocker cover look?
« Reply #1 on: July 31, 2024, 07:16:53 PM »
As long as the mating surface is flat, I’d run it without reservation. You could use a bit of JB Weld and scrape with a razor blade to shape the internal surface.
« Reply #2 on: July 31, 2024, 07:57:41 PM »
As long as its flat its fine
« Reply #3 on: July 31, 2024, 09:28:51 PM »
It looks adequate to me. :)
Offline wolf550
« Reply #4 on: August 01, 2024, 02:41:51 PM »
thanks guys I appreciate the it.
74' CB550 (Sold)
Offline newday777
« Reply #5 on: August 02, 2024, 06:24:02 AM »
Be sure to put in a new oring to be sure it will seal properly. Old rubber gets a flat spot and won't seal.
Stu
My current rides
Prior bikes....
Offline wolf550
« Reply #6 on: August 03, 2024, 05:02:05 PM »
thanks newday777. I remember the first time opening one up on frankenstein bike to look around just seeing how it all went together in there and then closing it back up. the first startup and alot of oil weeping all over.
74' CB550 (Sold)
