Author Topic: American Land Master UTV.  (Read 26104 times)
Offline grcamna2
Re: American Land Master UTV.
« Reply #125 on: December 20, 2025, 09:50:50 PM »
John, I saw the side wood 'fences' you made for it;that will help to have something to use to bungee large branches over the top also,when you need to.
75' CB400F/'bunch o' parts'
Offline BenelliSEI
  • 1969 cb750
« Reply #126 on: December 21, 2025, 07:19:26 AM »
Bill…… truthfully I had the table saw out and the leftover wood. Was looking for something to do with it and the UTV was sitting right there! That bin on the back had the six stake pockets and there was just enough wood. They need some sealer and red paint.
I suspect my wife will destroy them, next time she massively overloads the box. I did pick up a small 4’ X 4’ box trailer a few months ago(needs some work). This thing has an excellent hitch and will easily pull it around.
« Last Edit: December 21, 2025, 02:43:21 PM by BenelliSEI »
Offline grcamna2
« Reply #127 on: December 21, 2025, 02:51:45 PM »
I like the amount of visibility I see in the picture,and seating position,etc.  ;)
Offline BenelliSEI
  • 1969 cb750
« Reply #128 on: December 21, 2025, 08:31:48 PM »
Visibility is excellent, enhanced by a fold down wind screen. Initially I found the ride VERY stiff, until I dropped the tire pressures from 25 to 6-8 psi and it’s much improved!
« Last Edit: December 22, 2025, 06:34:54 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #129 on: December 22, 2025, 10:08:32 AM »
Paint and done.
Offline grcamna2
« Reply #130 on: December 22, 2025, 11:22:27 AM »
Paint and done.
I like the look of your completed Land MASTER John.  ;) :)
Offline BenelliSEI
  • 1969 cb750
« Reply #131 on: December 22, 2025, 11:47:08 AM »
Bill…. We just took it about a kilometre across our backfields to the hiking trails on our neighbour’s 200 acres of woods. The load of fire wood in the back really improves the traction in deep snow. May have to keep it full all winter!
Offline denward17
« Reply #132 on: December 22, 2025, 12:45:54 PM »
^John, I like the way you finished "trimming" it out with the red trim boards.
Offline BenelliSEI
  • 1969 cb750
« Reply #133 on: December 22, 2025, 01:47:41 PM »
Happened to have 1/2 a can of that red and it worked out well! Looks better balanced with some colour out back.
That plastic box is bolted to an angle iron frame that has only two large “hinge” bolts about 2/3 of the way back. There is a spring loaded locking latch up front. Even with the weight of all that wood, it’s quite easy to flip down the tailgate and dump.
I have a pile of 1.25” steel tubing that I scrounged some time ago. Thinking the next project might be to weld up a larger “flatbed” style deck for moving around larger stuff……..
« Last Edit: December 22, 2025, 02:08:16 PM by BenelliSEI »
Offline grcamna2
« Reply #134 on: December 22, 2025, 05:19:12 PM »
Will the plastic box be able to bolt-up to the new tube deck and dump;be nice to have the option for both.
Offline BenelliSEI
  • 1969 cb750
« Reply #135 on: December 22, 2025, 07:26:55 PM »
The existing boxe unit comes off with two large bolts through the hinge points. I’ll make them interchangeable.
Offline dhall57
« Reply #136 on: December 28, 2025, 09:39:55 AM »
New muffler on the Landmaster.
« Last Edit: December 28, 2025, 09:42:24 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline BenelliSEI
  • 1969 cb750
« Reply #137 on: December 28, 2025, 10:42:50 AM »
Did it make it any quieter? Mine has a smaller unit (Subaru 650cc Twin) facing straight back, with a smaller spark arrestor can on the back. It looks to be in good shape, but I wish it was a bit less noisy.
Offline dhall57
« Reply #138 on: December 28, 2025, 11:57:07 AM »
It's quieter no doubt. The old muffler was broke in several places.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline BenelliSEI
  • 1969 cb750
« Reply #139 on: December 28, 2025, 01:33:22 PM »
Well done. Mine is a standard can, about 1’ long and 10” in dia. I’m going to look for something about the same size and try an “upgrade”.
Offline dhall57
« Reply #140 on: December 28, 2025, 03:48:23 PM »
When I bought this from the rental company several years ago it had 2 different tire brands and tread patterns on it. The front were 4 ply and the rear 6 ply. I constantly had issues with side wall punctures so I purchased heavy duty 10 ply tires and so far no flats ;)
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline BenelliSEI
  • 1969 cb750
« Reply #141 on: December 28, 2025, 05:03:08 PM »
I’m sure mine is still on the O.E. tires. When I first got it they were at about 25 psi and the ride was brutal. I think I have them down to about 8 psi and the ride is much improved!!
