Author Topic: American Land Master UTV.  (Read 28905 times)
Re: American Land Master UTV.
« Reply #25 on: August 10, 2024, 10:41:30 AM »
Nice work John, good to add the convenience features. Good LED light bar could be a nice addition in the few times you might need to use it at night.
Offline BenelliSEI
  • 1969 cb750
« Reply #26 on: August 10, 2024, 12:27:30 PM »
I had to adjust the headlights down, but they actually work very well. Odd there were no rear lights at all. I used two lug holes in the back of the box (the kind you drop a 1/4-20 bolt into and the head locks in the hole) for my bracket and light. I suspect that’s exactly what they’re for and there was a light option. Very convenient!
Thanks for the link to the substitute oil choices. I’ll see if I can find any locally.
« Last Edit: August 10, 2024, 12:32:38 PM by BenelliSEI »
Offline grcamna2
« Reply #27 on: August 10, 2024, 02:38:01 PM »
Can this one be registered John ?
75' CB400F/'bunch o' parts'
« Reply #28 on: August 10, 2024, 03:08:11 PM »
Red Green always says, Guys remember, if you cannot be handsome, be handy...
So, I try to follow that sage advice...
Offline BenelliSEI
  • 1969 cb750
« Reply #29 on: August 10, 2024, 03:56:07 PM »
I can get a “green plate” permit for it and an ownership. I really have no plans to leave the property with it, so probably not going to do it.
Offline BenelliSEI
  • 1969 cb750
« Reply #30 on: August 13, 2024, 04:48:41 PM »
More fun with the LM650. When the seller accepted my very low offer, he added a comment. “The carb may need a cleaning, it occasionally stumbles and dies…..”. I fired it up and drove once around his property and it seemed to run just fine. Ever the optimist, I loaded it up and smiled to myself…..
Sure enough, it did what he said. It just seemed to be running out of gas. The carb was spotless, but the fuel pump seemed to run out of pressure every so often. I did order a pump from Amazon ($12.99). Blew up the suction line, cleaned some crap out of the bottom of the tank and thought, “Problem Solved!”. Put it back together and on we went.
Today it did it again and I thought no wonder he wanted it gone. I have the pump, so back I went. I started draining the tank and noticed the flow died to a trickle after a few minutes (just like last time). Pulled the fitting out of the bottom and found a bit of string sucked into it, and some plastic bits in there too (see attached photo). It must have been a lanyard for the gas cap, that broke off and eventually sank to the bottom? The string was actually folded over and stuck in the fitting! Where the heck was it last time I did this?  "Ruby" runs much better now!
« Last Edit: August 13, 2024, 04:55:27 PM by BenelliSEI »
« Reply #31 on: August 13, 2024, 05:03:39 PM »
Glad you sorted it out John, hopefully you won't have other Easter eggs popping up ..or they will be simple to figure out and address
Offline BenelliSEI
  • 1969 cb750
« Reply #32 on: August 13, 2024, 05:09:49 PM »
Gave it a good, long, fast run later. Ran really well and no issues. The materials and build quality seem like it should last a while. Gave it a (first) wash! Cleans up nicely.
« Last Edit: August 14, 2024, 04:48:28 AM by BenelliSEI »
« Reply #33 on: August 14, 2024, 06:36:07 AM »
The transfer case uses  any standard  80W90 diff oil, but the front diff calls for a small amount of “Mobil Fluid 424”. The manual is adamant to use only the Mobil product. Can’t seem to find any here in less than a 5 gallon pail!! Anyone know a source for smaller quantities?
Here, John.  But I dont know if Jegs ships to CA? [or if it is cost effective??]
https://www.jegs.com/i/Mobil-1/652/101189-1/10002/-1?gad_source=1&gclid=Cj0KCQjwq_G1BhCSARIsACc7NxoR_FzJvjBqJvkddAbz29yJ-7PXVHk-MXhY5KoF2svPszU2g_ObuKoaAvNDEALw_wcB
« Reply #34 on: August 14, 2024, 10:29:10 AM »
Few eBay sellers have the 2.5 gallon jugs
Offline BenelliSEI
  • 1969 cb750
« Reply #35 on: August 16, 2024, 05:51:32 PM »
David….. turns out I can order some from LandMaster (like any other part) and they sell it in a small bottle that’s good for one oil change and a bit extra. It only takes a pint! I need a new Viton seal for the bottom of the gas tank, so probably next week.
« Last Edit: August 16, 2024, 05:53:44 PM by BenelliSEI »
« Reply #36 on: August 17, 2024, 07:37:46 AM »
That's fantastic! Great you were able to find that
Offline BenelliSEI
  • 1969 cb750
« Reply #37 on: August 21, 2024, 04:49:27 AM »
Ordered it today, and the Viton Seal that pushes into the fuel tank sump. It looses a few drops a day. I guess it’s getting harder and I’ve abused it too many times, clearing the suction line. It seems a day isn’t complete unless I get soaked in fuel at least once!
Offline grcamna2
« Reply #38 on: August 21, 2024, 11:19:41 AM »
John, you'll be the Land Master of your entire spread ! with that machine  :D  ;D
Offline BenelliSEI
  • 1969 cb750
« Reply #39 on: August 21, 2024, 11:31:41 AM »
Bill…. I’m liking this thing a lot! Two big pines dropped across one of our trails overnight. Dragged them out with the front winch, sawed them all up, ran them through to the splitter. Loaded up the LM and ran all the wood up to wood crib on the veranda. Backed right up to the edge and had it all stacked in minutes.
Lots of torque and feels like it will go anywhere. It’s only 4’ wide and has a very tight turning radius. Fits nicely in the garage. Simple construction, all accessible and easy to work on. I think it looks good too! Clever stuff.
« Last Edit: August 21, 2024, 12:13:13 PM by BenelliSEI »
Offline grcamna2
« Reply #40 on: August 21, 2024, 02:00:16 PM »
4 wheel drive too !  Full time 4-wheel,or can you switch it from 2 to 4 wheel ?
Offline BenelliSEI
  • 1969 cb750
« Reply #41 on: August 21, 2024, 02:58:30 PM »
Flick of a switch for 4 wheel drive and a lever to lock the rear diff. Very basic and it works. The tires are so aggressive I have yet to need 4 X 4!
« Last Edit: August 24, 2024, 02:02:01 PM by BenelliSEI »
« Reply #42 on: August 21, 2024, 03:59:49 PM »
It was definitely a good buy... hopefully the last one you ever need.  A friend in Sierra Vista has owned a yellow TomCar for years and few years back added the longer wheelbase version as well. They use them for fun on and around their property and when they go hunting...they are quite capable machines... Israeli design
Offline BenelliSEI
  • 1969 cb750
« Reply #43 on: August 21, 2024, 05:51:38 PM »
Definitely seems like a good buy. The previous owner was frustrated by the intermittent stalling, that was the fuel cap lanyard floating around in the tank! I’ve ordered the front differential oil from the manufacturer. Once that is changed, all fluids are “new”. The only other thing I can think of is to pull in some fresh brake fluid……. DOT3 so nothing special.
Offline rocket johnny
« Reply #44 on: August 21, 2024, 06:23:08 PM »
  i like basic .   henry ford once said he never saw a brake rod spring a leak ...
Offline BenelliSEI
  • 1969 cb750
« Reply #45 on: August 21, 2024, 06:44:15 PM »
I agree! Looking at parts list for this machine today and was pleased to see that 99% of the driveline parts are standard Dana bits. The 90 degree transfer case is a conveyor drive line part and the driveshaft is a simple piece of 1” round stock.
« Last Edit: August 22, 2024, 03:50:40 PM by BenelliSEI »
Offline grcamna2
« Reply #46 on: August 21, 2024, 07:06:46 PM »
New DOT 3,definitely.
Offline BenelliSEI
  • 1969 cb750
« Reply #47 on: August 21, 2024, 07:08:49 PM »
Yup. When the front diff oil arrives, it will happen.
Offline BenelliSEI
  • 1969 cb750
« Reply #48 on: August 24, 2024, 11:49:57 AM »
Front diff oil arrived, so it’s changed out. Pulled in some fresh brake fluid and set alignment. Lubricated all the rod ends, brake pads are at +75%, rear shoes look new.  Should be good for a while!
« Last Edit: August 24, 2024, 01:59:44 PM by BenelliSEI »
Offline grcamna2
« Reply #49 on: August 24, 2024, 02:43:35 PM »
How does it track in soft,swamp type wet ground ?
