Author Topic: '75 CB550 Keihin Carb Question  (Read 407 times)
Offline 88BuckMeister
« on: August 08, 2024, 12:37:53 PM »
Does anyone know off hand which model Keihin carb came on the 1975 CB550? I'm thinking I have to rejet my carbs, and I've found jetting kits that come with an assortment. Obviously based on some awesome advise from you all, not a permanent solution as name brand jets will be used once the proper jetting size is found, but I think I need the model of the carbs to ensure compatability for the jet kits. Thanks
Offline denward17
Re: '75 CB550 Keihin Carb Question
« Reply #1 on: August 08, 2024, 01:22:30 PM »
Probably 022A, but you really need to check the stamp on the side of each carb.
Online calj737
  • I refuse...
« Reply #2 on: August 08, 2024, 07:44:31 PM »
Not all brands of jets and needles are the same, despite their “sizes”. Needles and emulsion tubes differ the most from stock, and main/idle jets unless Keihin have had issues with sealing. Just to inform you…
Online Deltarider
« Reply #3 on: August 09, 2024, 12:31:46 AM »
Here is the overview.
CB500K2-ED Excel black
