Author Topic: K&N  (Read 480 times)
Offline Vintageguy
K&N
« on: August 11, 2024, 06:57:44 AM »
Anyone had any luck (good or bad) with K&N oil filter large O-rings?
Thank you for an/all responses.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: K&N
« Reply #1 on: August 11, 2024, 07:31:29 AM »
I use stock filters
1973 CB 750 K3
10/72 build Z1 Kawasaki
Re: K&N
« Reply #2 on: August 11, 2024, 09:34:22 AM »
I have K&N filters among others.
The o-ring is too thin as most of the other filters supplied o-rings.
Only 4mm thick, should be 4.5mm not less.
I bought a 50 pack of ID 89mm, thickness 4.5mm nitrile o-rings from UK.
Think it was here. They have other o-rings needed for the engine rebuild. I bought mostly viton except for this big o-ring.
https://www.ebay.com/itm/133667308715?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=UXpgn1gJSJe&sssrc=4429486&ssuid=XgCEg0CPSya&var=433115506906&widget_ver=artemis&media=COPY
The small o-ring on bolt can be better too.
I tested Viton ID 15 thickness 2.5 mm as used on oil pump and oil lines attachment to CB750 engine.
Tight fit but works fine. Just oil it and oress the bolt in the filter cover. No more oil weep from that place.
I bought a Honda stock big o-ring to compare thickness with, not for use  Not cheap. Horrible price when o-rings can be found  for a MUCH  lower price from o-ring sellers.
The big o-ring will survive at least 2 oil changes. I'll go for 3.....
Do not tighten the oil bolt too hard and compress the o-ring too much.
I did not tighten the caliper much when measured.
« Last Edit: August 11, 2024, 09:46:25 AM by PeWe »
