The pricing for the suspension stuff is pretty reasonable; Race Tech gold valves - $230, springs - $150, rear shocks (adj) - $475, so $855 total. Before I order this front suspension, these 35mm legs look kinda skinny. Plus, if I'm thinking about 750 brakes, does it make sense to swap to a different front end at this point? I would like to retain the original look with the rubber gaiters, so is there a worthwhile upgrade with larger tubes, better brake, and the stock look? Or should I ditch the gaiters and go with early CBR front end? I definitely want to keep a spoked wheel! I know, this is the slippery slope.
