Author Topic: Honda cb500 four k1 - extra clutch plate?  (Read 672 times)
Offline roque75
« on: August 21, 2024, 06:21:06 AM »
Hi everyone!!
Recently I had some gear dogs rounded and needed to change them.
I notice that my clutch had an extra clutch plate. So there was a plate between the gear and the first friction disk…
I measured the friction disks and they were fine!
I removed it and now I can’t get the clutch working properly.
Or it’s too loose and I seams that I’m forcing the gears selector, or it too tight and it seams that it’s reeving like some clutch is applied.
I know that o can reinstall it but I want to understand why since it’s not supposed to have 7 clutch plates. I think it’s suppose to have 7 friction disks and 6 plates.
Can someone help me understanding this?
I also want to be sure that installing an extra plate will not damage anything.
Cheers
Re: Honda cb500 four k1 - extra clutch plate?
« Reply #1 on: August 21, 2024, 06:34:15 AM »
What model and engine number is it, Honda did do some mods early on in the 500's life
Offline roque75
« Reply #2 on: August 21, 2024, 07:10:29 AM »
Not sure about the version now that I’m checking.
Engine has Cb500E-21xxxx
Frame has CB500-20xxxx
« Reply #3 on: August 21, 2024, 07:38:00 AM »
That should be after any clutch mods unless a po has fitted old parts.
Check out a K0 parts book to see if it looks more like yours.
Should be a pic of K0 clutch attaced where the back of the clutch centre is a loose plate held by a big ciclip, later ones were cast in one piece
« Last Edit: August 21, 2024, 07:41:55 AM by bryanj »
Offline roque75
« Reply #4 on: August 21, 2024, 08:00:46 AM »
Mine is already cast in one piece.
But it had an extra plate between the plate already casted and the first friction disc.
Before I removing it, it was shifting ok (but with dogs rounded).
« Reply #5 on: August 21, 2024, 09:32:02 AM »
I think somebody previous has mixed up a manual and years and put the extra plate in by mistake
Offline roque75
« Reply #6 on: August 21, 2024, 11:03:42 AM »
Yeah, I also think so.
But the truth is that before the shifting was working properly!
Could be any logic for adding the extra disc?
« Reply #7 on: August 21, 2024, 01:20:24 PM »
Logic no, dumbness yes
« Reply #8 on: August 21, 2024, 06:23:34 PM »
I've seen the extra steel ones installed when the aluminum ones warped and the owner could not get a new un-warped one (back plate). Then he switched plate counts steel & fiber to make the stack height come out right.
And it worked!
