I thought I invented the O-Ring trick. Great minds work alike, L0L! ...
You probably did and I probably read about it here.
I first used o-rings on my 750K5's floppy foot pegs probably back around '09.
Simple, elegant, and effective.
Simplest solution to the rear footpegs is new rubbers.
Thanks again for the tip! 3/4" x 1/8" O-rings worked great and are essentially invisible. And while they might be a tad short, my rubbers are not worn and still look pretty good; so the o-rings are the perfect solution for me.
And those rubbers must shrink up pretty fast. I seem to recall the passenger pegs on this bike were flopping around in the 1970's.
I'm not certain if it applies, but would it help to loosen all the engine mounts just enough to where the engine could be lightly pulled with straps or jacked a little to align the fit of the pipes ?
Can't remember who posted it, but someone here posted a step by step to installing 4-4 pipes and the step #1 was to loosen all the engine mounts. I'm still holding that procedure in my reserve bag of tricks; but only as a last resort so as to avoid any unintended alignment changes.
Thanks, and well done! On the pipe that is rattling or buzzing on the frame: try loosening off the rear footpeg bolt completely. Find a slim piece of wood you can jam between the frame and pipe (I’ve used a small piece of wood cut off a flat paint brush handle). Tighten everything backup and after a few rides, the wood usually disappears…. If not, pull it out. You’ll find the clearance you want has been generated by the heat and pressure. These pipes are mild steel and it does not take much to alter their shape a tiny amount.
Appreciate the nice comments John! I made good use of two different sizes of paint stirring sticks (1/8" and 1/4" thick) just as you described to mitigate the rattling on the left side. I'm considering pipes 1 & 2 complete... for now... except for the observation noted below in reply to Don R.
Your bike looks really terrific!
You're too kind John and might feel different if you got a little closer. But it is what it is and I'll be tickled to get it back on the road again. My first and current wife of 52 years and I, fell in love on this bike back in 1972.
... I'll check clearance to the shield before I cut the foot peg notch.
I'm really looking forward to hearing what you find when you tackle your pipes Don.
As I mentioned above, my left side is essentially done and I thought pipes 1 & 2 were going to be the most difficult. Not so, in my case. On the right side, I can make the #3 & #4 rear holes a little easier than on the left, but I'm having a hard time getting the #4 pipe to tuck in as close as I think it should be up front and achieve a good line up on the connecting tubes in the rear. I'm thinking the problem is a lack of clearance where the #4 pipe passes under the brake pedal pivot. It seems to me like the cut-out in the muffler needs to move aft... so the muffler can move inward as much necessary without impacting the brake pedal when things are tightened up.
I'd like to know where, on a stock K1, the #4 muffler weld seam lies (inboard or outboard) in relation to the clamping portion of the brake pedal? Is the muffler seam supposed to be inboard or outboard of the brake pedal clamp bolt?
Now, as to checking for clearance between the peg bracket and heat shield, before cutting your notch...
I strongly suggest you take a good look at the total combined length of the two muffler mount sleeves and peg bracket in comparison to the length of the OEM Honda bolt.
On my left side, with everything tightened up as much as I dare, there is only room for a flat washer under the nut with not enough space for a lock washer. I haven't got that far yet, on my right side, but I do know the outer muffler sleeve is long enough to cut a notch without impacting the heat shield. (About twice as much clearance as on the left). This makes me question the accuracy of the placement of the mounting sleeves in the individual mufflers. Is it possible that rather than modifying the front end of these pipes, it may be necessary, in some cases, to modify the mounting sleeves which may be too long or mis-located so as to prevent a proper tightening with all the specified hardware???
ZT
