Author Topic: 1974 CB550 Ticking After Top End Rebuild + Cam Swap  (Read 3092 times)
Offline Mkubs
Re: 1974 CB550 Ticking After Top End Rebuild + Cam Swap
« Reply #25 on: September 07, 2024, 03:27:07 PM »
Just measured the diameter of the old pistons....they are 58.95-59mm in diameter.
I'm going to swap the old pistons back in and put new, oversized rings in them.
« Reply #26 on: September 07, 2024, 04:34:19 PM »
Your old pistons were larger than stock if they measure at 59mm...if you are measuring with calipers then how much measurement error do you have?  Stock is 58.5mm diameter...
What type of hone did you use and what did the cylinders measure after honing?
It is not uncommon for cylinders to have eccentric wear, honing alone cannot correct this issue.
Align boring the cylinders to reestablish the cylinder alignment can restore some lost power from the cylinders drifting during initial break in when the material around the liners allowed the cylinders not to remain in alignment with the crankshaft. The metal for the cylinder surround was not ideal. Align boring restores that lost power, it is a one time issue as after break-in the material surrounding the cylinder liners stabilizes.
« Last Edit: September 07, 2024, 04:38:20 PM by RAFster122s »
Offline Mkubs
« Reply #27 on: September 07, 2024, 05:21:48 PM »
I need to get back into the cylinder to measure the diameter after honing.
I used the typical stone hone - https://www.common-motor.com/honda-motorcycle-cylinder-hone?srsltid=AfmBOopSlxKWhOVODCYMjrmYyyAUAF3GWs1BIFPhTn_cLwrNVXwY8FnI
From what I've read though, the piston to bore clearance for these is supposed to be no more than 0.026mm. My naive self didn't measure the current clearance, but it certainly looks to be more than 0.026mm. Hence why I think there might be piston slapping.
The picture of those 3 bores does not show much in the way of honing marks. Remind us, what compression values did you get for each cylinder? Are you detecting any blow-by last the rings?
Apologies, I should've clarified - the pictures are of the same cylinder. I was attempting to display the front to back play of the piston to the bore. I could be wrong, but is that not way too much space? Hence my thought that there is piston slapping.
Before the rebuild, the compression was measured at the following:
  • C1: 63psi
  • C2 and C3: 60psi
  • C4: 68psi
I still have to measure the compression after the piston and ring replacement, but each time I went into the engine, there was some sort of oil (and possibly water?) mixture. From what I've read, this could be due to the rings settling in and the engine needing to burn off the oil. I did go back in to re-align the rings to be oriented per the manuals instructions.
« Reply #28 on: September 07, 2024, 06:52:05 PM »
That looks too big to me
Offline Mkubs
« Reply #29 on: September 07, 2024, 06:57:00 PM »
I assume you're referring to the gap, correct?
« Last Edit: September 07, 2024, 07:39:06 PM by Mkubs »
« Reply #30 on: September 07, 2024, 07:51:17 PM »
Correct, but the only way to be certain is remove the cylinders plus one piston then check ring gaps and piston skirt clearance
Offline Mkubs
« Reply #31 on: September 08, 2024, 04:34:22 PM »
Got back into the engine today. Here are the following measurement...
  • Bore diameter of all 4 cylinders: 59.00mm (+/-0.02mm)
  • Diameter of piston skirt: 58.5mm
The new pistons that I put in here were part of a kit. Therefore, if the pistons are undersized, the rings will be as well. Now that that's confirmed, I'll be in the market for piston rings for 0.5mm oversized pistons. I'm going to put the original pistons back with the new rings since it didn't seem like there was substantial wear on the piston body.
I also believe the vertical striations on the cylinder walls confirm my suspicion of piston slapping (see pictures).
Anyone order piston rings from common motors? https://www.common-motor.com/honda-cb550k-cb550f-piston-rings?gad_source=1&gclid=Cj0KCQjw8--2BhCHARIsAF_w1gwi0konqQ5o-sp4fl8qpc42NBUHie_PPy2F7PUh18EzYuAcEfpGFNQaAo33EALw_wcB
On a separate note, when I got to the pistons, pistons 3 and 4 had a surprisingly larger amount of dirty oil/gas(?) built up on the top surface. Any thoughts as to possible causes?
Thank you again to all for the help! The feedback and expertise on this forum is invaluable.
« Last Edit: September 08, 2024, 04:38:05 PM by Mkubs »
« Reply #32 on: September 08, 2024, 05:13:23 PM »
 Deposits on the pistons and head can be caused by low compression and incomplete combustion.
« Reply #33 on: September 08, 2024, 06:35:57 PM »
That block has been overbored by 0.5mm and as said you can not just fit oversize rings, you need +0.50 mm oversize piston kits ASSUMING there is zero bore damage, or you need +1.0mm kits and a further rebore. Try cruzinimage in japan for piston kits
Offline Mkubs
« Reply #34 on: September 08, 2024, 06:57:49 PM »
I'd imagine the undersized pistons and rings aren't helping.
You don’t want to run 58.5mm pistons with any sized ring in a 59mm bore. The motor will not like it. You’ll damage the pistons, the bores, and blow oil like it’s a Cummins diesel.
As mentioned in an earlier posts, I didn't realize that the cylinders were overboard by 0.5mm. I thought I was putting new pistons and rings in a standard 58.5mm bore.
The pistons I removed (that I thought were original size) were actually already 59mm.
I'm going to measure whether or not the oversized ringson the 59mm pistons are still sufficient or if I'll need new ones, but I'll probably end up getting new ones anyway.
