Author Topic: Converting to 530 chain and sprockets from 630  (Read 355 times)
Offline Dime
« on: August 31, 2024, 05:54:27 PM »
Ok so I am trying to make sense of all the available parts I am seeing online.
I know the 78k had the 630 chain.
Is it as simple as ordering the 530 chain and sprockets for a 76 and earlier?
I feel like I am missing something along the line.
Appreciate any help. Thank you
Offline denward17
Re: Converting to 530 chain and sprockets from 630
« Reply #1 on: August 31, 2024, 05:59:06 PM »
http://forums.sohc4.net/index.php/topic,191326.msg2237729.html#msg2237729
I converted from 630 to 530 chain and sprockets, using JTF-338 (17)  and JTR-284 (48).
The JTF338 has a shoulder on one side, I initially installed with shoulder out, but after installing chain, it was rubbing the engine case.
I then reversed the front sprocket with shoulder inside, no more chain rub.
104 links if I recall correctly.
   530 MAX-O Chain - 530MAXO-104
Part #: 110946104 from Dennis Kirk.
From Randakks
Sprocket - Drive - Front - 530 - JTF 338 - 17 Tooth - CB650
SKU: BAJTF338-17
1
Sprocket - Drive - Rear - 530 - JTR 284 - 48 Tooth - CB750
later changed to 18 teeth on the front...
« Last Edit: August 31, 2024, 06:19:29 PM by denward17 »
Offline Dime
« Reply #2 on: August 31, 2024, 06:17:51 PM »
That is awesome! Thank you
Offline Dime
« Reply #3 on: August 31, 2024, 06:29:45 PM »
From Randakks
SKU: BAJTF338-17
1
Two questions. Was the 17 tooth too buzzy at highway speeds? Do you have a part number for the 18 tooth?
Thank you
Offline denward17
« Reply #4 on: August 31, 2024, 08:11:08 PM »
Yes, it was for me,
JT Sprockets - JTF288.18 - Steel.
Offline Dime
« Reply #5 on: September 01, 2024, 03:49:15 AM »
Yes, it was for me,
Perfect. Thank you. I found a Canadian supplier and it will cost a little over $200 to do the conversion. Not bad at all seeing as a belt for my old Harley is $400 alone. Very much looking forward to working on these Hondas.
