Author Topic: Help with signal lights wiring  (Read 941 times)
Offline Vhonda
« on: September 03, 2024, 05:13:12 PM »
1973 CB500
I should have left it alone !
I swapped the LED front signal back to stock signals and blew my 15A fuse twice.
I am using one of the LAMP-LED
I have my right side (throttle) signal working, but my front left (clutch) signal is not working. Currently the wire is disconnected, I tried two connections but they both blew my 15A fuse.
Now my Acewell Speedometer is not showing rpm and speed!
« Last Edit: September 03, 2024, 07:46:38 PM by Vhonda »
73' CB500
76' CB550k
77' Yamaha 750
Offline denward17
Re: Help with signal lights wiring
« Reply #1 on: September 03, 2024, 05:15:10 PM »
Is your green ground wire plugged in?
Offline Vhonda
« Reply #2 on: September 03, 2024, 05:19:33 PM »
these two green wires in the casing?  NO
(everything worked fine when I was using LED front lights)
where do they go?
73' CB500
76' CB550k
77' Yamaha 750
Offline Vhonda
« Reply #3 on: September 03, 2024, 05:22:03 PM »
I went from these LED with 3 wires back to stock.
73' CB500
76' CB550k
77' Yamaha 750
Offline denward17
« Reply #4 on: September 03, 2024, 05:27:59 PM »
I don't know about LEDs, but the normal turn signals on a '76 550 requires the green ground wires to be plugged to the main harness green connectors inside the headlight bucket.
The green wires you are holding in the pic goes to the turn signal grounding bolts on the inside of bucket, yes?
Offline Vhonda
« Reply #5 on: September 03, 2024, 05:35:05 PM »
Yes those two green wires are attached to the two bolts inside the housing.
ok here is what I did, found other green female to attach to
1st pic LEFT
2nd pic Right
« Last Edit: September 03, 2024, 05:37:09 PM by Vhonda »
73' CB500
76' CB550k
77' Yamaha 750
Offline Vhonda
« Reply #6 on: September 03, 2024, 05:42:16 PM »
now where does the front left (clutch side) signal wire go? It is a single wire.
the orange connectors? this is where my 15A fuse blew. marked by white tape.
MANUAL says orange is for left side signals I even checked and unplugged and it does indeed control the left signal. When I plug in the front stock signal to this 4 way plug it kills my 15A fuse.
« Last Edit: September 03, 2024, 06:17:36 PM by Vhonda »
73' CB500
76' CB550k
77' Yamaha 750
Offline Vhonda
« Reply #7 on: September 03, 2024, 05:46:15 PM »
full photo of nest
73' CB500
76' CB550k
77' Yamaha 750
Offline denward17
« Reply #8 on: September 03, 2024, 06:24:32 PM »
You should have an orange / white wire bundle from the main harness to connect it to.
Offline Vhonda
« Reply #9 on: September 03, 2024, 06:30:24 PM »
help me understand this green ground wire.
this bold attached to the green housing wire is to ground the bracket?
I attached it to the 3 connectors with the other green ground wires.
73' CB500
76' CB550k
77' Yamaha 750
Offline denward17
« Reply #10 on: September 03, 2024, 07:19:02 PM »
I think you have it attached correctly now.
Offline Vhonda
« Reply #11 on: September 03, 2024, 07:54:09 PM »
Not working
Connected green ground wires as shown.
Attached a single wire from the left signal assembly to the orange cluster, blew my 15A fuse again.
There are only 2 cluster: Orange (for left) and Greyish cluster (for right). The right side works, simple plug into cluster.
Calling it a day, any help would be appreciated, thanks
« Last Edit: September 03, 2024, 10:25:50 PM by Vhonda »
73' CB500
76' CB550k
77' Yamaha 750
Online bryanj
« Reply #12 on: September 04, 2024, 01:59:59 AM »
That suggests there is a trapped or shorted wire in the turn signal
Offline newday777
« Reply #13 on: September 04, 2024, 08:13:05 AM »
Orange is for the turn signal.
Orange/white(stripe) is the running light which turns off while the turn signal is flashing on that side.
Solid green is ground.
Stu
My current rides
Prior bikes....
Offline Vhonda
« Reply #14 on: September 04, 2024, 10:39:29 AM »
PROBLEM SOLVED: Pinched left signal wire at the frame, exposed wired, from rust/old wire, wired replaced and everything is back up. Thanks everyone.
73' CB500
76' CB550k
77' Yamaha 750
Online bryanj
« Reply #15 on: September 04, 2024, 11:22:49 AM »
Do i get a prize?
Offline Vhonda
« Reply #16 on: September 04, 2024, 02:30:18 PM »
how about a photo of the finished product
and if you have Venmo I can buy you a beer.
I had LED signals but went back to some OEM signals to preserve the vintage look.
« Last Edit: September 04, 2024, 02:32:14 PM by Vhonda »
73' CB500
76' CB550k
77' Yamaha 750
