Author Topic: Engine Oil Leak Repair  (Read 664 times)
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« on: September 07, 2024, 02:58:36 PM »
I have a small oil leak at the centre of my cylinder head gasket, a diffuse leak around the oil pan, and a leak which results in oil running down the side stand and also coating the gear change pedal.
None of these result in a great amount of oil loss, but they do result in a mess. I am not, as some will know, in a position to fix this definitively, so I thought about using this Rislone Engine oil leak repair stuff.
Has anyone any experience of this?
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline newday777
Re: Engine Oil Leak Repair
« Reply #1 on: September 07, 2024, 05:31:40 PM »
I haven't used it nor would I recommend it in these motors. Might clog the oil orifice and then ............
Stu
My current rides
Prior bikes....
« Reply #2 on: September 07, 2024, 05:36:26 PM »
The oil on the sidestand is most likely coming from the chain oiler. It used to oil a little bit, but since the seal inside the countershaft has shrunk now, it oils more than needed. Just turn the little screw in the center of the countershaft inward a turn or so, this will only let it oil at higher speeds.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: September 07, 2024, 06:05:47 PM »
Not to mention what effect it might have on the clutch...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #4 on: September 07, 2024, 06:49:45 PM »
I think that is more for leaking seals than gaskets and as said i wouldnt use any thickening stuff on a honda
« Reply #5 on: September 07, 2024, 06:56:40 PM »
Well, that’s decided then; more visits to the car wash.
Thanks all.
CB450 K1 - Stalled.
