Author Topic: Starting issues  (Read 425 times)
Offline SantaFeHonda
Starting issues
« on: September 08, 2024, 11:20:19 AM »
1977 CB750K. I just got this bike a few weeks ago and have only ridden it a couple of times so far. When I first got it it seemed to start up with no problem. It has now gotten to where it won't start without several tries and constant recharging of the battery. It sounds like it's not getting gas but after trying to start it for a while it starts to smell like it's flooded. Any suggestions where I might start looking for causes?
« Last Edit: September 08, 2024, 11:22:09 AM by SantaFeHonda »
Re: Starting issues
« Reply #1 on: September 08, 2024, 11:23:26 AM »
Check your spark plugs: are they clean and dry? Sooty and dry? Sooty and wet? Clean and wet?
Re: Starting issues
« Reply #2 on: September 08, 2024, 11:38:52 AM »
What type of carbs has it got
Re: Starting issues
« Reply #3 on: September 08, 2024, 11:48:14 AM »
The plugs are relatively new and look clean. The carbs are Kei Hin. Additionally, when I do get it to start it runs great with no smoke from the pipes.
Re: Starting issues
« Reply #4 on: September 08, 2024, 12:09:04 PM »
This might seem like an odd question (since I don't know your experience with these bikes?) but...are you familiar with the 1970s- style fuel petcock operation on the fuel tank?
I once tried to 'help' someone for several days before I discovered his 750 was the first motorcycle he'd ever owned, and he didn't understand how the fuel has to be turned OFF when parked and ON or RESERVE when running. :(
Re: Starting issues
« Reply #5 on: September 08, 2024, 12:30:33 PM »
Yes, I've owned a couple of bikes, a 1974 CB750 back in the 70's and 80's. I just got back here after pulling the plugs to inspect them and after putting them back in it decided to start. I'm going to take it out for a quick run and see how it runs now.
Re: Starting issues
« Reply #6 on: September 08, 2024, 12:51:59 PM »
All the 750 have Keihn carbs but its the type that matters, is the top a round screw on or a P shape held on with 2 cross point screws
Re: Starting issues
« Reply #7 on: September 08, 2024, 04:03:16 PM »
I'll have to go check the carbs. More tomorrow.
Re: Starting issues
« Reply #8 on: September 08, 2024, 05:16:54 PM »
 A 77 didn't come with the round top carburetors but they often get installed due to the lean characteristics of the 77 carbs .
Offline newday777
Re: Starting issues
« Reply #9 on: September 08, 2024, 06:26:59 PM »
Looking at his posts he has roundtops.
Stu
My current rides
Prior bikes....
Re: Starting issues
« Reply #10 on: September 08, 2024, 06:31:12 PM »
I know the F had the problematic PD carbs but the K was rare in UK so i dont know about that one which is why i asked
Offline newday777
Re: Starting issues
« Reply #11 on: September 08, 2024, 06:40:24 PM »
Looking at your posts someone has put roundtop carbs on your K7 frame.
Look at the flat surface on the motor side of the slide to get the body numbers
Stu
My current rides
Prior bikes....
Re: Starting issues
« Reply #12 on: September 09, 2024, 08:13:39 PM »
That shot looks like a K4/5?
Offline BenelliSEI
  • 1969 cb750
Re: Starting issues
« Reply #13 on: September 10, 2024, 10:22:36 AM »
It’s a “bitsa”. Very nicely done too!
