Author Topic: CL 350 vintage racer project  (Read 477 times)
Offline emlupi
« on: September 09, 2024, 07:01:04 AM »
Good morning,
I have been posting on the Honda twins forum but the traffic over there is pretty thin. I’m building a vintage racer for use in a spec formula CB350 class. Engine mods are very limited but I am looking to build the engine so it will stand up to the rigors of track use.
It has been suggested to use a copper head gasket for this application. What is the group’s opinion of this and what sort of special instructions would I need to heed for this installation?
Also, Honda is no longer supplying OEM gaskets for these machines. I know there are many sources for aftermarket gasket kits, etc. Does anyone have suggestions for which suppliers have quality parts and, more importantly, which should be avoided?
 I appreciate any advice you can provide, thanks.
Offline CycleRanger
  • No comment about being an
Re: CL 350 vintage racer project
« Reply #1 on: September 09, 2024, 07:17:50 AM »
The HT forum died when it got sold.
Head over to https://www.vintagehondatwins.com/
All the knowledgeable vets are there.
As far as gasket sets, OEM A&B sets can usually be found on ebay.
Offline emlupi
« Reply #2 on: September 09, 2024, 07:47:43 AM »
Thanks CycleRanger,
Appreciate the help. I knew someone here would get me pointed in the right direction.
Online newday777
« Reply #3 on: September 09, 2024, 08:02:35 AM »
What year is your 350?
I might know someone in NH that has NOS gaskets for some of the old twins.
Stu
My current rides
Prior bikes....
Offline emlupi
« Reply #4 on: September 10, 2024, 09:47:06 AM »
It’s a 1973 CL350K5. That would be quite helpful, thanks.
Online newday777
« Reply #5 on: September 10, 2024, 10:06:13 AM »
Are you boring it bigger? You will need a bigger head gasket if so.
Where are you located??
Stu
My current rides
Prior bikes....
Online newday777
« Reply #6 on: September 10, 2024, 10:18:09 AM »
Base gasket available
https://www.hondarestoration.com/photodetail.asp?hrPart=12191-312-000
He doesn't have the head gasket butCMS in Holland shows they have 1.
You could try David Silver Spares (warehouse in PA as well as England)
Stu
My current rides
Prior bikes....
