Author Topic: Size of ground wire munit to battery  (Read 2349 times)
Offline toadm
« on: September 14, 2024, 08:41:02 AM »
Hi. I have a 76CB750F with munit blue, ricks regulator rectifier and Shorai lithium battery. My munit GND connection is connected to the engine ground wire via a 6 AWG cable. I understand I should/could have an additional ground wire connection from munit GND connection direct to the battery, and use a 14 or 16 AWG wire. Is this correct? Can I use a second, direct GND connection using 14 or 16 AWG wire from battery to GND on munit?
Thanks in advance
Offline toadm
Re: Size of ground wire munit to battery
« Reply #1 on: September 15, 2024, 07:22:55 AM »
Yes. 10-12AWG would be better.
Thanks so much!
