Author Topic: 69 speedo drive  (Read 499 times)
Offline 69cb750
69 speedo drive
« on: September 14, 2024, 11:43:58 AM »
There is a flat part that joins the forked part in the speedo drive with the forked part on the speedometer cable.
Do these pull out of the speedo drive ?
Can I get one out of any speedo drive ?
Offline newday777
Re: 69 speedo drive
« Reply #1 on: September 14, 2024, 12:03:50 PM »
I'm not sure if there are different parts as I haven't taken any apart nor read of anyone doing so.
What's up with yours?
Stu
My current rides
Prior bikes....
Offline 69cb750
Re: 69 speedo drive
« Reply #2 on: September 14, 2024, 12:19:45 PM »
MIA, probably came out with old speedo cable which is long gone.
Offline CycleRanger
  • No comment about being an
Re: 69 speedo drive
« Reply #3 on: September 14, 2024, 01:17:44 PM »
The speedo drive can be taken apart.
I've done it but I can't remember if the pinion gear was secured by a roll pin on the 750 drive. Might have been. It's been so long I can't remember and I don't have one to look at atm.
I know it was on my CL350 because I just did that one a couple of weeks back.
Either way I believe the internal components are the same for the K bikes at least up to '76.
It that your drive in the photo?
Offline newday777
Re: 69 speedo drive
« Reply #4 on: September 14, 2024, 01:49:51 PM »
If your serial number is above 1044649, then the speedo drive box is the same to K8.
Earlier have a different part number of the drive box assembly,  probably to mate to the Earlier drive plate fins.
Stu
My current rides
Prior bikes....
Re: 69 speedo drive
« Reply #5 on: September 14, 2024, 01:59:07 PM »
   Any 69 is going to have a pretty low serial number, probably below 10,000. I've mixed and matched speedo gear boxes pretty haphazardly not noticing differences except in the drive plate. I'd bet the drive gear stayed the same.
Offline 69cb750
Re: 69 speedo drive
« Reply #6 on: September 15, 2024, 04:26:08 AM »
Thanks to everyone that posted.
I will get another speedo drive for parts.
