Author Topic: Tank Dent Removal on Honda SL350K0  (Read 1800 times)
Offline pjandrew99
« on: September 18, 2024, 04:14:03 AM »
My CB750K1 tank had a few dents that I was able to remove with the PDR rods. Came out great.
This SL350 tank is a different story. The dent is on the left side which provides very little access for the PDR rods.
I will be repainting the tank if I can get this dent out enough to use a reasonable amount of filler and skim coat.
What I have tried so far:
1- High heat than cold. No good
2- Inner tube/air. No good
3- Hot melt PDR kit. Marginal at best
4- Harbor Freight Stud Welder. Terrible and put hole in the tank.
My latest attempt is soldering a bolt on to the dent with 30/70 solder. One pull and it came right off.
I'm pretty careful about prep with all these methods. I can't get anything to work.
I saw someone on a forum suggest silver solder. Before I throw more money into this tank I'm hoping to get some direction.
Maybe this is my excuse to buy a welder? I'm thinking that is my only option. Either welding a bolt on to the dent or opening up the tank, pushing the dent out and sealing the tank back up. I have no welding skills so that could be a disaster.
Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline Oddjob
Re: Tank Dent Removal on Honda SL350K0
« Reply #1 on: September 18, 2024, 04:40:20 AM »
No offense Calj but that sounds like a recipe for disaster. He has NO welding skills. Cutting a hole in the bottom of the tank means petrol sitting on the weld, any pinprick hole will mean a leak. Cutting a hole ABOVE the dent is a much better idea IF you really want to cut a hole at all.
Take it to someone who can weld, get them to weld a rod or 2 onto the dent and pull the dent out with some sort of slide hammer is my advice.
Offline pjandrew99
« Reply #2 on: September 19, 2024, 01:54:56 AM »
Welding seems like the way to go. Appreciate the help!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: September 20, 2024, 02:05:29 PM »
Based on my recent experience, take it to a good PDR shop. They can work miracles!
