Author Topic: 1978 cb750k- and so it begins  (Read 5617 times)
Offline Dime
Re: 1978 cb750k- and so it begins
« Reply #50 on: December 30, 2024, 08:55:00 AM »
The machined cones finally showed up after the postal strike. Grabbed a length of 3/4-10 threaded rod, nuts and washers and set it up.
No issue with the frame. Measured from multiple points and it is not out. Very thankful.
Offline Dime
« Reply #51 on: January 04, 2025, 02:11:55 PM »
The new triple tree top clamp showed up and it fits perfectly. A lot cleaner than the original top clamp. Once I know for sure how I am mounting the speedo and tach I will remove the excess mounts to clean it up some more.
The new top clamp is off a 1981 kz1000 CRS. The rest of the front end is a 1981 kz1000 ltd
Sent from my SM-S721W using Tapatalk
« Reply #52 on: January 12, 2025, 04:58:34 PM »
 That front end should look cool.
 It's too bad everybody lives so far apart. I have a frame jig made from 2X3 box tubing tacked together, I checked out a similar frame on it.
  At the rear it has 1/2" steel mounts with holes for the 20mm axle and the swingarm. The front has frame shims and clamps. For measuring, I used plumb bobs and a triple tree with a piece of chrome moly tube inserted through it.
Offline Dime
« Reply #53 on: January 12, 2025, 05:07:35 PM »
Thanks Don. I think the front end will work out good.
Yes it is too bad we are not closer. I would definitely like to utilize the frame jig you have. Not to mention see your collection.
