Author Topic: Weldless frame kit in Norway / Sweden  (Read 2293 times)
Offline Torkels
  • Honda CB750 K2
« on: September 30, 2024, 03:04:36 AM »
Anybody from Norway / Sweden that has a view on the cutting of frame and use of the weldless frame kit with regards to legislation?
Re: Weldless frame kit in Norway / Sweden
« Reply #1 on: September 30, 2024, 08:04:55 AM »
PeWe is out resident expert from Sweden, he should be along shortly.
I believe he had a frame kit on one of his bikes.
« Reply #2 on: September 30, 2024, 11:21:30 AM »
Hi,
Here when I cut my frame
http://forums.sohc4.net/index.php/topic,62832.msg1505075.html#msg1505075
Here initially with Mikuni VM29  Smoothbores carbs, one year later Mikuni TMR 32.
I should cut same again if I needed.
I have had great use of it. I have lost count of how many head and cyl off I have done. Changed cams for test runs etc.
Open valve cover for inspections etc, etc.
I have removed head, cylinder, HD studs and pistons + everything else for pulling the engine.
Only  CB750 bottom, I used a strap and could swing it out of frame beside bike on a soft surface on the garage floor.
Took it apart for upgrades, still on the floor.
Assemble and everything  back in reverse order.
No need for lifting help.
I think I have shown how I time cam with engine in frame.
« Last Edit: October 04, 2024, 12:02:59 AM by PeWe »
Offline Torkels
  • Honda CB750 K2
« Reply #3 on: October 01, 2024, 04:11:15 AM »
Thanks for replies. I am looking for a kit, seems like Scottly was empty and no immediate plans to fabricate new sets.
« Reply #4 on: October 09, 2024, 08:25:14 AM »
Search that will be close:
split collar tube clamp
60-70 mm long. My clamps by Frank are ca 61mm
ID must be tight around frame. If 1" will be tight enough.
