Author Topic: It's Alive!  (Read 587 times)
Offline Duanob
  • Bold Timer
  • Gotcha!
It's Alive!
« on: October 01, 2024, 03:34:44 PM »
Got this project back on the road. Still some fine tuning. The 4 into 1 sounds great. Went through the carbs completely and synced. Complete brake refurbish, all new or newer cables and hoses, oil, spark plugs, chain, fork oil, new rubber, some new electrical. Adjusted just about everything there was to adjust. The final was the clutch, I'd almost forgot how to do that.
a couple of final questions, I searched for a proper plug chop but couldn't find one, does anybody have a tutorial or vid. I'd like to see how the carbs are mixed at idle, mid range and WOT.
And if someone can refresh my memory for Keihin 087A carbs, the idle screw is screw out for more air?
« Last Edit: October 01, 2024, 03:37:28 PM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline newday777
Re: It's Alive!
« Reply #1 on: October 01, 2024, 03:59:53 PM »
Stu
My current rides
Prior bikes....
Offline newday777
Re: It's Alive!
« Reply #2 on: October 01, 2024, 04:01:56 PM »
And congratulations on getting it running
Stu
My current rides
Prior bikes....
Offline grcamna2
Re: It's Alive!
« Reply #3 on: October 01, 2024, 04:35:26 PM »
+1
Offline jonda500
Re: It's Alive!
« Reply #4 on: October 01, 2024, 09:04:42 PM »
"screw out for more air?"
Yes, for those carbs screw the idle mixture screws out for more air (leaner), in for less air (richer).
John
A starter clutch thread:
Offline Flyin900
Re: It's Alive!
« Reply #5 on: October 02, 2024, 06:26:57 AM »
John
Are you sure that's correct? I always thought that the adjustment screw on the engine side was a fuel screw and on the air box side an air screw. Don't those carbs have the adjustment screw on the engine side?
Just clarifying for my own knowledge.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline jonda500
Re: It's Alive!
« Reply #6 on: October 02, 2024, 07:20:00 AM »
John
The PD carbs found on 77/78 550K's have fuel screws. Those 087A carbs clearly have the screws on the air filter side so they are air screws, you thought correct!
John
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: It's Alive!
« Reply #7 on: October 02, 2024, 09:41:47 AM »
Thanks all! It's been 10 years since I last worked on one of these but thanks to you all it's all coming back. I forgot how much fun it is figuring these 4.bangers out and getting them back on the road.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
