Author Topic: Motad exhaust system .  (Read 893 times)
Offline bmwbrads
« on: October 05, 2024, 01:50:41 AM »
Hi I have a 76 400/4 with a motad exhaust system the pipes from 1and 4  are very blue at the head ?. .Is this normal?. Thanks
Offline Deltarider
Re: Motad exhaust system .
« Reply #1 on: October 05, 2024, 01:55:43 AM »
Welcome. Maybe it's better you ask the Brits. I believe Motad was made in the UK. www.sohc.co.uk
CB500K2-ED Excel black
Offline Little_Phil
« Reply #2 on: October 05, 2024, 03:31:00 AM »
Early Motads were steel with chrome finish. Has the discolouration suddenly occurred? Suggest some cylinders are running hotter than others, but not unusual as Motad pipes are single skinned and often all blue a bit.
Later Motads are S/stl and discolour to a straw color.
Offline bmwbrads
« Reply #3 on: October 05, 2024, 05:43:41 AM »
I have just got the bike took it for only a 2 mile run when i got back it refused to tickover plus the two pipes were very blue .Pipes slightly blue before the run .Cheers
Offline Tim2005
« Reply #4 on: October 05, 2024, 12:00:17 PM »
They shouldn't blue differently. It indicates those cylinders are running too hot, which could be due to a lean mixture caused by blocked carb jets or similar, but as it is 1 and 4 they share the same ignition set so I would first check that the timing is correct and not set too advanced. Over-advanced ignition will cause overheating badly. Even retarded ignition can cause overheating.
Offline pekingduck
« Reply #5 on: October 06, 2024, 06:44:14 AM »
Agree with Tim2005 - possibly from improper timing, either too far advanced OR too far retarded. Also, too rich can cause it, since an over-rich condition, like retarded ignition, can cause an incomplete combustion that continues to burn as it exits the exhaust port.
Offline Tracksnblades1
« Reply #6 on: October 06, 2024, 06:31:00 PM »
I’m thinking it’s a lean mixture that blues the single wall chrome pipes…
In a rich condition the excess fuel can become a coolant.. orange flames are generally cooler than pretty blue ones..
Age Quod Agis
« Reply #7 on: October 07, 2024, 10:01:54 AM »
+1...sounds like it could be lean.  Pull the plugs and "read" them...
