Author Topic: Sunrise CB550F cafe  (Read 3318 times)
Offline MisterKnife
Sunrise CB550F cafe
« on: October 06, 2024, 07:53:55 AM »
Think it's time to make a proper build log.
Bought this almost 2 years ago now. ( I already had redone the rear tire, carbs and exhaust ) It was in decent condition. But if you looked closely it wasn't maintained well.
Stripped bolts on covers, stipped threading on cylinder head, missing head bolt ( how!? ). To name a few.
Couple months ago I swapped the frontend to a GSXR750 from 06 with a cognito moto hub / tripple tree. Refurbished the suspension / brakes and stripped all the electronics and made my own diagram for it.
For the bars got motogadget buttons, signal lights on the end, motoclassic gauge, messnermoto throttle and a set of masters from a hayabusa for the clutch and brake.
Designed my own rearset mounts ( loosly based on the ones from messnermoto ) made them a bit more forward so the toe wouldn't interfere with the kickstarter ( removed the starter ) which works like a charm
Planned to be added:
- cleaner solution for the rear fendor
- redo subframe to get a straight line from tank
- lower front light by 2 cm with new brackets
- engine rework / vapor honed / cerakote ( I sourced a NOS cylinder head and had it staged 3 by Mike, will add the 592/62s from dynoman )
- little bit bigger front fendor
- custom side stand bit more forward to make room for 4 -> 2 custom exhaust
- custom exhaust
It's a bunch but I'm not in a rush and currently moving to a new house which requires a LOT of work to get me going.
« Last Edit: October 06, 2024, 07:56:34 AM by MisterKnife »
Offline bassboy3313
Re: Sunrise CB550F cafe
« Reply #1 on: October 08, 2024, 07:53:32 AM »
Looking good! Any chance you have the template for the rearset brackets you made? I am looking to make some myself. Thanks!
Offline MisterKnife
« Reply #2 on: October 08, 2024, 08:05:18 AM »
Here you go. it's a CNC machined part. had mine produced by https://www.rapiddirect.com/ for around 100 a piece. get them in 6061-T6 ( that's what I used for mine and tested in a simulation )
For the F model you do need a bigger peg bolt. The 550K bolt is long enough. and some washers on the left side to get some spacing 1mm
« Last Edit: October 08, 2024, 08:06:54 AM by MisterKnife »
Offline bassboy3313
« Reply #3 on: October 08, 2024, 09:04:43 AM »
Thank you! Do you have more pics on how they mount to the bike frame?
Offline MisterKnife
« Reply #4 on: October 08, 2024, 10:03:08 AM »
same as the cognito moto one.
I do suggest getting this nut. so you can fit a 21hex socket on there. a 22 doesn't fix
https://www.amazon.nl/-/en/dp/B076NS6PKD?ref=ppx_yo2ov_dt_b_fed_asin_title
Offline GaJet
« Reply #5 on: December 16, 2024, 07:52:57 PM »
So how do you like the cognito moto front fork swap? How much has handling a breaking improved?
1976 CB750F
1977 CB750K
Stock is Boring
Offline MisterKnife
« Reply #6 on: January 21, 2025, 03:04:35 AM »
God, it's a whole different bike. I brake with 1 finger now. Cornering feels also a lot more solid. And having a rebound in my shocks is just a godsend.
Offline GaJet
« Reply #7 on: January 22, 2025, 02:42:23 PM »
Thats good to know.
1976 CB750F
1977 CB750K
Stock is Boring
Offline twentyover
« Reply #8 on: April 07, 2025, 02:35:05 PM »
Little bit late to the game, but what size wheels and tires you running? I have an old 550 that has lester WM2 front and WM3 rear, was thinking I might run those
Offline MisterKnife
« Reply #9 on: October 21, 2025, 01:34:53 PM »
I'm back at it—rebuilding the engine block.
We finally moved into our new house where I have a small workspace, so it's time to get this project rolling.
The photo is a little late, as the entire motor is already out. I sent the upper crankcase to a machine shop to get a stubborn broken head bolt removed, which they handled nicely. They also bored out the sleeves for the new 61mm pistons while it was there.
I've since degreased the block and dropped it off for a Cerakote finish: Tungsten on the block and Armored Black on the fins. It’s going to look great.
I also bought a '78 donor motor a few months back to compare internals and snag its improved valve cover. I’ve since picked the best parts from both engines, cleaned everything, and have it all bagged and tagged for the final build.Now I’m just waiting to get the casings back so I can start cleaning out all the passages.
Offline MisterKnife
« Reply #10 on: October 21, 2025, 01:38:02 PM »
Running two 18" rims with Conti RoadAttack3 CRs. 110 front 130 rear
Offline Shtonecb500
    • Youtube profile
« Reply #11 on: October 23, 2025, 08:39:56 PM »
I dig the black rims, I run the same look on my 750. I still cant convince myself to do a gsxr swap...I guess I need to ride one/try one.
Every way I chop it up its comes out to 1k for a fork upgrade, so do I want to keep it period correct or upgrade to modern....Its been years and I still won't pull the trigger.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline MisterKnife
« Reply #12 on: November 02, 2025, 01:27:06 AM »
Just done the final wash of all the medium. Really dig the colors
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #13 on: November 02, 2025, 06:56:09 AM »
I wish I could figure out why I'm not able to see the attached .jpg's
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline newday777
« Reply #14 on: November 02, 2025, 07:06:10 AM »
This is why
http://forums.sohc4.net/index.php/topic,206017.0.html
Stu
My current rides
Prior bikes....
Offline MisterKnife
« Reply #15 on: November 03, 2025, 02:39:47 AM »
Couple more pics
Offline denward17
« Reply #16 on: November 03, 2025, 04:41:43 AM »
^Love the that finish on the engine/side covers!
Offline Godffery
  • Godffery's Garage
« Reply #17 on: November 25, 2025, 08:12:45 PM »
 Following.
Offline BenelliSEI
  • 1969 cb750
« Reply #18 on: November 26, 2025, 05:40:43 AM »
Interesting finishes. What carbs are you planning to use?
Offline MisterKnife
« Reply #19 on: December 02, 2025, 12:09:20 AM »
Let's do a little update,
- I've got the cases back together and all the lower stuff assembled.
- Redid my wiring a bit and got that as well knocked off my list.
- Made a licence plate bracket that also holds a plate light.
- Made new throttle cables to length for the CR26's
- Spaced out the CR26's to the correct spacing
Currently waiting on some new piston rings as I #$%*ed over one oil ring during instalation ( also needed a rehone at my local shop )
Picking up my gas tank at a chemical cleaning plant that are removing an old liner, then that tank gets send to get a 1/4npt bung ( for a pingel as the normal petcock interferes with the new carbs) and a professional liner.
« Last Edit: December 02, 2025, 12:12:16 AM by MisterKnife »
Offline MisterKnife
« Reply #20 on: December 02, 2025, 12:10:40 AM »
Some more images
Offline MisterKnife
« Reply #21 on: December 02, 2025, 12:11:35 AM »
Some more images
Offline BenelliSEI
  • 1969 cb750
« Reply #22 on: December 02, 2025, 12:59:53 PM »
Looking good!
Offline MisterKnife
« Reply #23 on: December 15, 2025, 06:52:04 AM »
Small update, made a starter spacer as I won't be using the electric starter. This saves some weight.
Printed in PCPBTGF so temp won't be an issue if your worried ;-)
Offline BenelliSEI
  • 1969 cb750
« Reply #24 on: December 15, 2025, 01:39:30 PM »
Why not just eliminate it entirely?
