Author Topic: Close ratio gears for CB250/350 and CB500 on way  (Read 23502 times)
Offline Dresda500
« on: October 10, 2024, 10:51:35 AM »
Just an FYI! I’ll put up a separate ad on the for sale section with actual pricing and whatnot, I just wanted to post here as at least myself, I don’t look at the for sale section that often .
 I have been working with Nova Racing in the UK for the past year to develope some close ratio gears for Honda CB250/350 K twin and the CB500-4. I have a batch of close ratio gears for both 1st and 5th gear available for both type engines.
1st gear is a 37t, down from 40t (uses same mating so, 17/37 now) and are drop in on all engines.
 For 5th gear, it is the same as previous Nova delivered, but no longer offered, 29t (29t/27t). This one is square dog design, so drop in for the 250/350 K. On the CB500, you must swap on the 2nd/3rd gear cluster and 4th square dog from the CB350K, as the CB500 is round dog...this is the only change and good used gears are availble for next to nothing on Ebay etc.
These are not a stocking item at Nova and not available for purchase direct and likely a one time order from myself....only 10 gears of each type available
« Last Edit: October 31, 2024, 12:16:47 PM by Dresda500 »
Instagram: hansrodncycle
Roadracing CB250K, Dresda CB500 and Martin KZ1000
Special intrest in hand made frames/bikes, porting/flowbench and Dyno tuning of vintage bikes
Offline turboguzzi
Re: Close ratio gears for CB250/350 and CB500 on way
« Reply #1 on: October 13, 2024, 02:25:23 PM »
nice dresda, good luck finding clients.... strongly suggest to you to post in honda twins forums, dont think there much request for these from 500 sohc4 racers,
Offline richmagee7
« Reply #2 on: October 15, 2024, 07:21:25 AM »
Turboguzzi may be correct but I'm interested for my 500 land speed racer.  In fact, I have a ebay OEM CB350k 2nd/3rd gear cluster arriving today.
Rich
Offline Dresda500
« Reply #3 on: October 15, 2024, 10:10:31 AM »
The 500 gears are actually selling better than the Twin gears.....In the nordic racing series, Norway, Sweden, Finland and Denmark, probably 40% of the bikes are CB500. Two of the top three are CB500, the other being a Drixl 450 big bore. But that said, it's not a money maker, I'll be lucky to break even, but it will get my Dresda CB500 hopefully firmly planted in the top group if I'm lucky.
I'd be honored to have one out on the salt. As a 200mph Club member, that place has a special place in my heart. As you know THE MOST important gear change to have a close ratio is the top gear. Send me a mail or msg and I'll get you sorted.
Offline simon#42
  • liverpool
« Reply #4 on: October 15, 2024, 10:54:07 AM »
having stuff made like this tends not to make you rich . hats off to you for making the gears available though .
Offline richmagee7
« Reply #5 on: October 16, 2024, 02:17:26 PM »
DM sent Dresda
Offline Dresda500
« Reply #6 on: October 31, 2024, 12:18:36 PM »
Haha, absolutely correct...quite the opposite in fact... ;D
