Author Topic: Resolved Red's issue - finally  (Read 3632 times)
« on: October 13, 2024, 09:45:17 AM »
Red was giving me trouble.  It had less power in low rpms, it idled well.  It had hiccups in high rev.
I had carbs out like 4 times cleaning and checking fuel level.  I replaced coils with a different set, replaced spark plugs.
It felt like the signal from the ignition shortens out.  I pulled the ignition with cable and the advancer.  The Pamco rotor is aluminum and it was rusted solid with the advancer. Taking it apart I killed the advancer,  found another one and she started right  up
Gotta say it had me puzzled for a long time.
Offline BenelliSEI
  • 1969 cb750
Re: Resolved Red's issue - finally
« Reply #1 on: October 13, 2024, 12:01:28 PM »
Nice find! Well done.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #2 on: October 13, 2024, 02:16:15 PM »
I have found in my experience that most carburetor problems are electrical in nature!
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #3 on: October 14, 2024, 07:45:46 AM »
It's been my experience that once the issue is found, it tends to make a lot more sense of why the bike [or vehicle] had the issue!
« Reply #4 on: October 15, 2024, 03:48:08 AM »
Same experience  ;D
Offline rotortiller
« Reply #5 on: October 16, 2024, 12:17:21 AM »
I’d consider a light coating of dielectric grease on the outside of the rotor to help prevent this in the future.
That's what  I did with the inside of the aluminum advance rotor on my Tytronics ignition. Was worried about the heat and thought anti-seize but dielectric grease did the trick. The rotor freedom does get checked once in a while because the advance unit is the only moving part of the ignition system.
I set it up so there is no need to adjust the timing when the ignition is removed and installed from the engine for advance unit service. This was done by rotating the timing plate to the end of its travel on the 3 mounting screws and then adjusting the individual pickups for correct timing.
« Reply #6 on: October 16, 2024, 06:49:21 AM »
For timing I used a scriber and made a line from the ignition plate to the engine counterpart.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #7 on: October 16, 2024, 07:37:22 AM »
Good find!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline rotortiller
« Reply #8 on: October 17, 2024, 03:35:56 AM »
When I lost my near sight as an old tuck, flipping the old 't' and feel is all I have left in me lol!  ;D
