Author Topic: CB400f aftermarket piston kit  (Read 4212 times)
Offline 9toe
« on: October 13, 2024, 07:30:42 PM »
Any recommendations for aftermarket piston kits for a ‘75 CB400F pistons? I have seen some from Cruz in Images, 4 into 1 and some on eBay. My stock honda piston are oval. Cylinder are true.
Offline Nurse Julie
Re: CB400f aftermarket piston kit
« Reply #1 on: October 14, 2024, 01:06:21 AM »
Cruzinimage kits are excellent.
Trust me I'm a Nurse, I promise it won't hurt....much
Offline newday777
« Reply #2 on: October 14, 2024, 03:07:19 AM »
Did you use a machinist quality bore mic to measure the bore of the cylinders to be sure they are not tapered, as they usually wear in to be? Always best to do a fresh bore up size by +.25 at minimum(1st oversize set). You say you have oval pistons, so get bigger pistons and rings sets with fresh bores to tight tolerance clearance that these baby Fours require. Hondaman says they need to be .0004"-.0008" piston clearance, not bigger piston clearance so you don't have burning oil from too big of piston clearance.
Cruzin Image comes highly recommended as quality piston sets.
4into1.com doesn't come highly recommended. Cheap Chinese parts are not good quality items.
Read through this project rebuild
http://forums.sohc4.net/index.php?topic=179579.75
« Last Edit: October 14, 2024, 03:12:10 AM by newday777 »
Stu
My current rides
Prior bikes....
Online bryanj
« Reply #3 on: October 14, 2024, 08:22:13 AM »
How oval? Most piston are fractionaly bigger front to back than side to side, a lot of car piston are measurably "oval"
The advise for a rebore is good BUT  you must use a machinist who understands Honda motorcycles plus recently i have found the 500/550 will not "clean" at 0.25mm due to barrelling of the liners
« Reply #4 on: October 14, 2024, 07:50:13 PM »
I second that motion.
Offline 9toe
« Reply #5 on: October 15, 2024, 09:19:02 PM »
Cruising piston kits, got it and thanks. I will post some pics of the pistons. Cylinder to piston clearance is .0004 - .0008, that is a tight tolerance.
