Author Topic: Fork offset data  (Read 5372 times)
Offline emlupi
Fork offset data
« on: October 16, 2024, 12:08:16 PM »
Good afternoon all,
Is there a source to find out the offset dimensions of the front forks for various model years of the CB750’s? If so, I would appreciate the information, thanks.
Re: Fork offset data
« Reply #1 on: October 16, 2024, 12:35:06 PM »
 The biggest difference is between the K and F but I don't have numbers. I bought a highly modified 750 that had 500 triple trees on it for reduced offset.
Offline Alan F.
« Reply #2 on: October 16, 2024, 09:16:58 PM »
I understood K0-K6 were the same and K7 & K8 were different.
Offline paul_cb836
« Reply #3 on: October 17, 2024, 12:44:26 AM »
Been discussed many times in High Performance section. Do a search - for example a post by ‘Scotty’ dated 2/4/2019 lists fork offset for K0-K6 and F1-f3 as well as fork lengths etc.
Offline emlupi
« Reply #4 on: October 17, 2024, 06:55:13 AM »
Will do, thanks.
« Reply #5 on: October 17, 2024, 08:47:46 AM »
 I'm sure we had a discussion on this a couple years ago when I found the cb500 forks and triple trees on a cb750 frame. I did a search but didn't find the information yet.
« Reply #6 on: October 17, 2024, 08:51:09 AM »
 Often, google does a better job of finding posts here than search does. This is a discussion of rake and trail which I assume relates to the question and your answers are there too.
http://forums.sohc4.net/index.php?topic=176882.0
« Last Edit: October 17, 2024, 08:56:58 AM by Don R »
Offline emlupi
« Reply #7 on: October 17, 2024, 09:58:37 AM »
Good reading and very informative. Thanks for the link.
« Reply #8 on: October 18, 2024, 09:55:12 AM »
 I'm thinking the 550 offset was 45mm.
« Reply #9 on: October 18, 2024, 07:45:50 PM »
The 550 offset is the same as the K7/K8 and the F models.
