SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Fuel line question - 75 CB400F
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Fuel line question - 75 CB400F (Read 229 times)
krksquared
Enthusiast
on:
November 03, 2024, 11:11:45 AM »
Looks like a T fitting between the two center carbs is loose as can be seen by the linked video. Shouldn't be this way - right? I've never been this deep into the bike. O rings on the T? Looks like a bit of a struggle to get in there. Carbs need to come off? I don't like the idea of gas leaking in that area (or any other area)! Also, is 4.8mm fuel line hard to come by?
https://www.nostalgickitscentral.com/mustang/fuel%20line.mov
Logged
@kennectwithme
1975 CB400F
1971 SL350
1979 CBX
2007 Buell XB9R
2003 Harley V-Rod VRSCA
If it ain't broke, I'm riding...
CycleRanger
No comment about being an
Really Old Timer ...
Central Texas Shop Manual Advocate
Re: Fuel line question - 75 CB400F
Reply #1 on:
November 03, 2024, 11:50:58 AM »
Yep, the carb rack has to come out
and
apart to change those o-rings.
The good news is Honda still sells the "packing set" (O-rings, gaskets) for those carbs.
PN 16010-333-315
They also sell the proper fuel line.
Logged
CB750K5 '79 XL250s CL350K3
CB750K3 '76 XS650 '76 CJ360T
krksquared
Enthusiast
Reply #2 on:
November 03, 2024, 01:20:18 PM »
Thanks for the info! The things you discover when fixing something else
Better now than later!
Logged
@kennectwithme
1975 CB400F
1971 SL350
1979 CBX
2007 Buell XB9R
BenelliSEI
1969 cb750
Reply #3 on:
November 03, 2024, 02:30:30 PM »
If you don’t change the “0” rings on the tees, be patient. They may drip for a while, swell up and seat. Usually when that happens in the Spring, I make a note to replace them, next Winter!
Logged
carnivorous chicken
Master
Reply #4 on:
November 03, 2024, 02:37:06 PM »
Also, these carbs are like other SOHC carbs where that T can wiggle a little, so the fact that it is moving isn't necessarily something bad. Better to see if it is actually leaking.
Last Edit: November 03, 2024, 02:50:03 PM by carnivorous chicken
Logged
bryanj
CB500 Number 1000036
Reply #5 on:
November 03, 2024, 03:07:38 PM »
Be very carefull with the tee, a lot are plastic and you cant buy it seperately
Logged
Don R
My Sandcast is a
Saver of unloved motorcycles.
Reply #6 on:
November 03, 2024, 03:09:11 PM »
I changed the tee on a KZ1000 and did remove the rack but only took two carbs loose enough to slip the tee out.
Logged
krksquared
Enthusiast
Reply #7 on:
November 03, 2024, 03:19:54 PM »
Hey you talked me into checking for leakage. I'd never noticed any leaking before but it's hard to see in there with the tank on and I always close the tank valve when parked. If I can get out of pulling the carbs, I'm all for that. And if I consume it faster than it leaks - no big deal haha. The only thing worse would be my CBX! Hmm maybe it's time to check that one too...
Logged
@kennectwithme
1975 CB400F
1971 SL350
1979 CBX
2007 Buell XB9R
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
