Author Topic: Switching heads between years  (Read 140 times)
Offline richmagee7
« on: November 16, 2024, 08:31:14 PM »
Looking to switch the heads between my 73 750k and my 75 750k.  I don't see much difference between the heads.  But just looking for some reassurance that I'm not missing something.  When I pulled the head off the 75 I was reminded that the cylinders had the 8 extra 'packing' rubbers and pins around the cylinder head studs.  My 73's cylinders do not.  But I see no difference in the heads.  Is there some difference in the head I am missing?
Why am I switching you might ask?  The 73 was a project, had Mike Rieck do a bang up job on the head, thought I would use the bike differently but now want to sell the bike and keep that head.  The 75 is my first 750, my ride or die, and I want to refurbish it some.  Do a better job painting the engine this time, finally paint the frame, replace many things rusted from Bonneville, etc.  And I thought the head might be weeping oil though it seems now it was just the cam cover.  Anyway, switching the heads.  Any reason it won't work?
Thanks, Rich
Re: Switching heads between years
« Reply #1 on: November 17, 2024, 12:46:57 AM »
No problem.
My K6-76 has used 1972 head after its K6 head.
Now a 392 from K7/K8 + F bikes (except F2/3).
Cylinder earlier type with smaller oil return holes close to head.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: November 17, 2024, 05:31:54 AM »
No problem.
+1. Use the headgasket for the head you are using.
« Reply #3 on: November 17, 2024, 05:55:52 AM »
No problem.
And cylinder.
Later cylinder has 8 wider oil return holes. Honda stock has 8 high o-rings + special knock pins.
Later gasket can be used with earlier style cylinders too. Possible to add o-rings with fiber gasket.
MLS late style on earlier cylinders are fine as is. I use  2 o-rings for oil to head
Offline richmagee7
« Reply #4 on: November 17, 2024, 07:13:06 AM »
Thanks guys!
Rich
