Author Topic: 1975 CB550k Carb Base shaft bushing  (Read 113 times)
Offline Shutt24
« on: November 18, 2024, 10:26:59 AM »
I removed the shaft to clean and the bronze bushing is broken. I measured it at .375 id x .500 od x .525 length. If anyone has a resource for the bronze bushing I would greatly appreciate it.
Re: 1975 CB550k Carb Base shaft bushing
« Reply #1 on: November 18, 2024, 10:52:34 AM »
You will have to have one specialy made, you did not fully remove the locking pin
Offline Shutt24
« Reply #2 on: November 18, 2024, 02:57:08 PM »
What is the best way to remove the locking pin?
« Reply #3 on: November 18, 2024, 03:13:09 PM »
Normally I just tap/drive them thru to the opposite side with a punch and small hammer (small, so the shaft doesn't get bent!).
While I don't have brass that size on hand, I do have a small lathe to make one with if it comes to that.
Offline Shutt24
« Reply #4 on: November 19, 2024, 03:23:47 AM »
I will give that a try. Don’t know why I didn’t see that.
I bought these on amazon, I hope they work.
Offline newday777
« Reply #5 on: November 19, 2024, 04:49:57 AM »
You need bronze, not steel bushings so they don't rust and freeze to the shaft.
Stu
My current rides
Prior bikes....
