Author Topic: Ignition Signal Motoscope Mini & Combi Frame  (Read 93 times)
Offline toadm
« on: November 23, 2024, 10:45:12 AM »
Hi. Have a 76 CB750F with munit blue. About to replace stock instruments with the motoscope mini & combi frame (w/LEDs). Few questions:
(1) Does anyone have a wiring diagram with this setup?
(2) The motoscope mini has yellow wire for rev signal. Given that this will no longer use stock tach cable, is there anywhere else to tap into for ignition signal or do I need to purchase and install a Motogadget Ignition Signal Sensor (or similar) to pick up?
Any guidance or recos appreciated.
Thanks so much!
