Author Topic: How to remove steering head upper race ?  (Read 300 times)
Offline Laids
« on: November 24, 2024, 12:31:25 PM »
I have never run into this issue before. The upper race in the steering head is inset from the lip.
Anyone have any tips how to get it out? I’ve read somewhere about tig welding onto it.
Offline Alan F.
Re: How to remove steering head upper race ?
« Reply #1 on: November 24, 2024, 12:45:23 PM »
Normally one would tap it up and out from the bottom with a wooden dowel through the frame neck.
I can't tell from your picture if the race is larger than the neck's ID. Is that the issue? Ouch. I would probably grind a slot with a demmel without worrying much about damaging the frame. Not the best advice for everyone though.
« Last Edit: November 24, 2024, 12:50:56 PM by Alan F. »
Online bryanj
« Reply #2 on: November 24, 2024, 01:16:51 PM »
Dremel a slot or put a run of electric weld round inside the race stick, mig, tig whatever you have
Offline Laids
« Reply #3 on: November 24, 2024, 02:11:13 PM »
It’s a K1 that has been sitting for about 30 years and appears to have never been molested. Everything so far has come apart without to much effort so I guess something had to come up. Not relishing attacking it with a Dremel.
Offline rotortiller
« Reply #4 on: November 24, 2024, 02:52:21 PM »
Some of the tapered roller bearings for that modification type are built that way. You are going to have to blast.
Online bryanj
« Reply #5 on: November 24, 2024, 03:30:35 PM »
Enlarging that pic i am not even sure a race is in there
Offline Laids
« Reply #6 on: November 24, 2024, 03:40:39 PM »
The race is there, I wish it wasn’t  :o
Offline craz1
  • CDA, Idaho
« Reply #7 on: November 24, 2024, 03:42:25 PM »
Looks like a tapered race. I use a washer that fits at approximately the center of the race and tac weld it in three-four spots then you can tap it out. With the heat it will normally drop out easy.
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
Offline Laids
« Reply #8 on: November 24, 2024, 04:04:22 PM »
Sounds like a good idea
Offline Oddjob
« Reply #9 on: November 25, 2024, 05:14:02 AM »
That was my first thought, it doesn't look like a taper race, more like a bush has been fitted. What's the measurement of the frame collar above it, as I'm thinking you may find it's the same as everyone else's.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #10 on: November 25, 2024, 06:38:13 AM »
Good carbide burr and a high speed grinder should work. Messy but effective
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Phoenix
  • 4 wheels move the body. 2 wheels move the soul
« Reply #11 on: November 25, 2024, 12:25:11 PM »
What am I missing.  As someone said, a wooden dowl or screwdriver and some good blasts with a hammer from the other end.
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
Offline Oddjob
« Reply #12 on: November 25, 2024, 12:37:07 PM »
It’s inset from the headstock so there is no lip to hit against. Which makes me think it’s not a race but a bush, plus I see no slope like a taper roller has, looks flat sided to me unless it’s the camera angle.
Online bryanj
« Reply #13 on: November 25, 2024, 01:53:02 PM »
That is what i was trying to say, a taper would normaly stick out of the top and yes have no "lip" to tap on to remove, the standard ball race has a plenty big enough "lip" into the centre to hit on to remove.
Whats in there just does not look right, do you have pictures of the rest of the upper bearing? They may hep sort out what has been done
Offline Laids
« Reply #14 on: November 25, 2024, 02:02:04 PM »
Got it figured out, it is a bush and I’m an idiot. Retrieved the races from the garbage, all accounted for. They were removed a week ago and I already had forgotten.😜
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #15 on: November 26, 2024, 06:49:15 AM »
Good thing, saved you a lot of trouble.
I wonder why the bushing is in there.
1973 CB 750 K3
Offline Oddjob
« Reply #16 on: November 26, 2024, 07:04:41 AM »
I'm thinking to enlarge the seating area for the race as the frame lip may have been deemed to be not up to the stress.
Offline Laids
« Reply #17 on: November 26, 2024, 09:14:17 AM »
It certainly confused me, which is apparently not hard to do. I just did a K4 7 months ago and no confusion .
Offline craz1
  • CDA, Idaho
« Reply #18 on: November 27, 2024, 06:43:44 AM »
Looking at it again it ism a bushing. Kinda had a tapered look from the camera angle the first time I looked at it.
Glad you got its figured out.
Offline Laids
« Reply #19 on: November 27, 2024, 07:10:14 AM »
Anyone have a pic of a KO steering head top without the races in?
