Author Topic: Using CB500 Needles in a CB550F  (Read 155 times)
Offline jaytee-nz
« on: December 01, 2024, 06:13:47 PM »
I discovered the carb needles on my 1976 CB550F were badly worn when I first started it after a restoration. It would start without the choke and blow greyish, rich smelling fumes. I tried the usual fix of dropping the needle to the last (top) position as it was already in the 4th position. This made no change at all. I checked the needles with a jeweler's eyepiece and found that all 4 were marked with striations all along them from top to bottom, presumably from rattling inside the emulsion tube due to excessive wear.
That's when I found that new needles are as rare as rocking horse crap, and I didn't want to use aftermarket ones.
As I have a few spare CB500 627B carb sets, I decided to swap the needles from these into my 069A carbs, along with their emulsion tubes (as they have slightly different hole sizes).
After a test run today, I'm very happy with the bike's performance and it doesn't run rich anymore.
My bike is totally stock other than a Delkevic 4 into1 exhaust system.
Re: Using CB500 Needles in a CB550F
« Reply #1 on: December 01, 2024, 10:07:44 PM »
yeah good one,id do that,years ago mates older suzy 750 ran rich,popped off carb tops and two needles(aluminium)had worn as flat as a match stick on one side the front side,im guessing the air draught caused that?got two new needles and fixed.
Offline jaytee-nz
« Reply #2 on: December 01, 2024, 10:34:24 PM »
Yeah, I had a very similar problem with a CB750 years ago Dave, so I knew what the issue was likely to be. My needles weren't as bad as those Suzuki ones though !
