Author Topic: Alternator rotor stuck - help please  (Read 403 times)
Offline Cevan
« on: December 15, 2024, 08:49:23 AM »
Disassembling my 500K1 engine.  The rotor is really stuck.  I literally stripped the M16 removal bolt.   I used progressively more air in my impact gun and disaster.   I have a three leg puller on it now and nothing is budging it.   I’ve tried heating it for 10 full minutes and nothing.
Any suggestions?
« Last Edit: December 15, 2024, 04:50:39 PM by Cevan »
Re: Alternator rotor stuck - help please
« Reply #1 on: December 15, 2024, 03:00:06 PM »
If you have put that much heat in yes it does need to come off to replace the crank seal behind it, a 3 leg puller will have damaged the rotor, crank or both but it doesnt need to come off to split the cases and remove crank assembly
You need the proper 4 way honda puller and a hide mallet, never failed me yet
Offline Bodi
« Reply #2 on: December 16, 2024, 09:02:36 AM »
Stripped the bolt or the rotor threads? The Honda tool is a hardened "bolt", if you used a hardware store bolt I'm not surprised that it stripped.
« Reply #3 on: December 16, 2024, 10:13:07 AM »
Yeow!
Yeah, they get stuck: I use extensive heating with a MAPP gas torch of the rotor, myself. Heat guns and propane almost never work. When it starts smoking off the old oil on it, it's getting close to ready. Keep a fire extinguisher handy as old oil starts to burn at those temps.
Then polish the end of the crank and the ID of the rotor with fine Scotchbrite before reassembly. It will take about an hour to cool.
« Reply #4 on: December 16, 2024, 12:03:32 PM »
 The big Suzuki's are known to spin the rotor on the crankshaft, one of the cures is supposedly to get it warmed up and rattle it onto the crank while it's expanded.
Offline Dr. Frankenstein
« Reply #5 on: December 16, 2024, 12:32:00 PM »
I have a 500K too, I was really surprised to see that there isn't a woodruff key on the end of the 500K shaft...I used the Honda bolt to get mine off, but I was surprised to not see a woodruff key on it.
« Reply #6 on: December 16, 2024, 12:42:18 PM »
Dont need it, they get damned tight without, although there was a bulletin fot early 750 altering the torque for the bolt but that has the starter clutch on the back as well
Offline Cevan
« Reply #7 on: December 16, 2024, 01:30:15 PM »
I got it free. The crank is undamaged. What stripped was the extractor bowl which I thought was hardened steel. Was not a hardware store bolt.Will need to source a new rotor. I hit it with some PB blaster overnight and then went at it with more heat.  Eventually popped right off.
« Last Edit: December 16, 2024, 01:32:13 PM by Cevan »
« Reply #8 on: December 16, 2024, 07:24:13 PM »
Good job!
Merry Christmas!
« Reply #9 on: December 16, 2024, 11:51:31 PM »
Any 500 or 550 rotor is the same
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #10 on: December 17, 2024, 06:39:49 AM »
Great news, I hope finding the rotor isn't too hard.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Cevan
« Reply #11 on: December 17, 2024, 06:02:23 PM »
There’s a few on EBay.  I’ve got a ways to go before I need it.  Here’s the current state of the engine.  Not sure what happened.  😀
« Reply #12 on: December 17, 2024, 06:36:06 PM »
It musta been goin' mighty fast!
