Author Topic: Quality K8 carb boots for early k head to Mikuni 34mm Flatslides  (Read 2107 times)
Offline dragracer
  • CB750F Dragbike
Re: Quality K8 carb boots for early k head to Mikuni 34mm Flatslides
« Reply #25 on: January 01, 2025, 01:27:30 PM »
Can't a #1 boot be flipped over and fit on #4, and likewise for #2 and #3?
  I wondered that also but Honda gave them each a different part number.
Yes, because each one is marked on the top with the cylinder #. ;) I recall seeing some boots that had a 1 on one side, and a 4 on the other side: if used on the #1 cylinder, the 1 went on top with the 4 on the bottom, and if used on the #4 cylinder the 4 went on top. Try it and see if it works or not.
My plan is to try your suggestion Scottly.  I much rather use the OEM Honda parts.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #26 on: January 01, 2025, 06:40:29 PM »
Yes
Offline willbird
« Reply #27 on: January 03, 2025, 02:20:52 PM »
That is how the new OEM boots I bought from Ebay are, I never knew there were FOUR part numbers for boots 1-4 ?? Always presumed that there were only two. I have been messing around cad modeling intake boots and just ordered a digital height gage to actually measure/model the features on the cylinder head and work from there rather than using a boot and working from those numbers.
Bill
Online scottly
« Reply #28 on: January 03, 2025, 07:28:56 PM »
The original K7 boots I have are actually marked 1, Z, 3, 4. ;D ;D
Offline dragracer
  • CB750F Dragbike
« Reply #29 on: January 04, 2025, 07:05:49 PM »
I went ahead and ordered another #1 OEM boot. I'll try it on the #4 side. It doesn't have to be exact stock  spacing anyway because the 34's are off a bit anyhow.
« Reply #30 on: January 04, 2025, 08:33:33 PM »
Bill.
 The thing to remember is these are K8 boots for the keyhole carbs, not the same as the other cb750 boots.
Offline dragracer
  • CB750F Dragbike
« Reply #31 on: January 04, 2025, 08:48:29 PM »
Bill.
Correct Don. The head side is comparable to all other K heads but the inlet side is larger. They work perfectly for the 34mm Flatslide Mikunis when installing them on any head except the F2/3 which has larger intake spigots. I typically use a drum sander roll on my drill to open up the inlet a tad larger so the 34's won't be as hard to slip on. I cut a little at a time to be certain its snug. In theory,  1 and 4 should be similar in configuration as you're only rotating the boot, 180 degrees on the spigot.
« Reply #32 on: January 04, 2025, 09:53:36 PM »
 It makes perfect sense to me. It got me curious about the K0/K1-6 carb rubber difference. I've had mid-year carb rubbers on an early bike since before I joined here.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #33 on: January 05, 2025, 04:35:23 PM »
Bill
Oooooo... 3D CNC machined aluminum intake manifolds with wide flat rubber o-rings on the inlet port at the head and an o-ring on the carb outlet. Make it so!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline willbird
« Reply #34 on: January 06, 2025, 08:56:22 AM »
Bill
I am fresh out of CNC's but the general idea is to create a fairly accurate 3D model and then we can examine all kinds of ideas :-).
Bill
