Reminds me about next plug shop coming spring or at least main jet check on my Blue K6 970cc.
WAT check from 180kmh to verify the response is as it has been before at its best. A clear acceleration, not only more screaming.
I reduced pilot jet and fuel screw to solve minor too rich at slow throttle roll-offs at 80kmh and less on 5th gear, only possible to notice downhill.
Fixed that so the total amount of fuel reduced so I had to raise the needles 1/2 notch by a washer. Better.
MJ increased one 2.5 step which made it better, no pinging as I heard earlier at WOT, pinging at 7000 rpm on 5th gear.
Season ended Oct 20 so high speed check need another test.
I have roads for it but it is always a tingling feeling before a main jet check in high speed.
Another thing when higher speed just happen
I have reduced the acc pump stroke due to much black smoke at idle revving this winter. It was at max setting.
So the throttle response 100-160kmh (needles) and from 160/180kmh have to be redone.
Plus cruise in 140-150 kmh for a few km to read the outer plugs I can reach on a hot engine.
MJ test by cruising to at least 200kmh according to speedo plus WOT, there a slow throttle roll-off to feel if bike will accelerate during roll-offs (lean) or just slow down (OK).
If hearing a d-d-d-d sound, too rich.
I verified needle cruising last ride not too rich. (100-160kmh small throttle increase followed by roll-offs, in steps up to 160kmh.)
Typical for carbs when they might be perfect. It is needed to continue until it runs bad to clarify it was good before.
The only question left is:
Can I raise the needles 1/2 notch and/or increase main jets another 2.5 step?
It can be good as is too;D
Both have been too lean before the last 2 rides where I adjusted needles and MJ richer and better.
I have been in situations when doing MJ tests. Slow going cars driven in 60/70kmh on a 80 signed road will suddenly pop-up in my face behind a corner or uphill when riding above 160kmh.
I thanked myself for the working dual front brakes making front tire to squeal.
The legal speed area can be tricky to get right. But most important. Not fun to ride when that is not ok.
More carb rides done, more small errors you will notice.
