« Reply #80 on: February 01, 2025, 10:51:20 AM »
Does anyone know why there might be two small holes in the roof of the float bowl in one carb and only one in the other? And could this be part of my problem? It makes me think the carbs might be different…
The carbs are stamped behind the backing plate which I don’t want to take off, before someone asks hahaha
To share the bowl vent with the outside carb bowl.
You have 2 vent hoses, both hooked to the 2 and 3 carbs, because of the slide going down through the center blocking a pathway to go straight across the body, so they just add the second bowl vent hole in the 2/3 carbs, it's the pathway to the outside 1/4 carbs.
Logged
Stu
My current rides
Prior bikes....
